Remote Start? - Pontiac GTO Forum
post #1 of 12 (permalink) Old 01-04-2011, 11:36 AM Thread Starter
hockey499s's Avatar
Remote Start?
has anyone here put a remote start in their gto? do you know what was invloved? did you lose your spare key doing it? have to use a bypass?...ect..
My 2005 GTO
hockey499s is offline
post #2 of 12 (permalink) Old 01-04-2011, 01:00 PM
HP11's Avatar
I've never heard of anyone doing one the worked for any length of time. Here's a couple of thereads where it was discussed:
GTO Anti-Theft/Remote start?
2006 Remote Starter in Tucson AZ
HP11 is online now
post #3 of 12 (permalink) Old 01-06-2011, 06:50 PM
waverun2000's Avatar
Ok guys I created an account because it seems like no one knows this answer.
There is a bypass that directed makes and it uses one of your keys. There is a "nipple" on the side of the key that makes contact with a metal ring around the key cylinder. There is also a small electrical charge running through the key also. So in order to make it work you have to solder the tip of the key and the nipple to the bypass in order to make it work. You then connect that to the wires attached to the key cylinder. We have a digram at work I will see if I can get if you guys want it.
waverun2000 is offline
post #4 of 12 (permalink) Old 01-06-2011, 07:14 PM
Here you guys go.
Future GTO owner
Current 2001 Blazer owner
post #5 of 12 (permalink) Old 01-06-2011, 07:29 PM
HP11's Avatar
Originally Posted by waverun2000 View Post
Here you guys go.
I've seen that but do you know anyone who actually has one of those installed and working on a 04-06 GTO?
HP11 is online now
post #6 of 12 (permalink) Old 01-06-2011, 08:08 PM
Yes coworker did one. There is a diagram out there that shows that you can bypass it by cutting the purple key sense wire and running that to the relay. That diagram is garabage but this works. The key has a constantly changing risistance, that is why you have to solder the key in the circuit.
Future GTO owner
post #7 of 12 (permalink) Old 01-07-2011, 06:55 AM
HP11's Avatar
Wouldn't that end up in such a way that anyone with a remote from one of those systems would be able to start your car?
HP11 is online now
post #8 of 12 (permalink) Old 01-07-2011, 09:59 AM
No because each remote start system has its own unique frequency. Just like how your key does not unlock anyone else GTO. It does mean however if someone was able to pick the ignition cylinder and get it to turn the car would start because it thinks the key is always in the ignition. It would be very hard to pick the ignition cylinder because it is hard to pick a flat key ignition.
Future GTO owner
post #9 of 12 (permalink) Old 01-07-2011, 12:32 PM
HP11's Avatar
I would think a car thief would just pop the ignition and with the key already locked and loaded he'd have one less step to deal with. I'll pass........
HP11 is online now
post #10 of 12 (permalink) Old 01-08-2011, 09:37 AM
GM4life's Avatar
Yeah by-passing the theft system is not a good idea on a car that not designd for remote start. Also if you have a manual shifted car its not a good idea.
GM4life is offline
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
Human Verification
remote control '69 xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 4 03-26-2010 07:42 PM
GTO Anti-Theft/Remote start? PnYeaTr Interior Discussions 7 02-28-2010 01:18 PM
Radio Problems and remote start issues. dcoen21 Service, Maintenance and Technical Discussion 3 09-06-2009 06:48 AM
Remote start for an 05 AlanSr 2004-2006 GTO General Discussion 2 01-08-2008 12:26 PM
Remote starters... criminally_sane Interior Discussions 6 11-30-2006 07:50 PM
