Storage question - Pontiac GTO Forum
 2Likes
  • 2 Post By DavidTX2
post #1 of 4 (permalink) Old 01-08-2017, 06:33 PM Thread Starter
Storage question
My 06 is put away for the winter, have a battery tender on and stabilizer in gas. Last winter I started the car and let it run for twenty minutes or so. I've read where some people say to start them up from time to time and others say leave them alone until its time to start driving again. Which is best?
dmrock is offline
post #2 of 4 (permalink) Old 01-12-2017, 02:59 PM
You are referring to short time storage and it is better to start the car and let it come up to operating temperature for 15 minutes. Recommend you do it every month or two. If your short term is less than 1 year it is not necessary to drive the car to keep the seals pliable like what was required many years ago when the seals were made from leather.
HP11 and dmrock like this.
DavidTX2 is offline
post #3 of 4 (permalink) Old 01-13-2017, 07:53 AM
If your going to start the car, do it every couple of weeks for about 15 minutes. Also, inflate your tires to 40 lbs to insure no flat spots.
I have had cars on battery tender for the winter with a full tank of stabilized fuel and 40 psi without starting and everything was fine when driving weather arrived.
newsandu002 is offline
post #4 of 4 (permalink) Old 01-13-2017, 06:24 PM Thread Starter
Thanks for the reply, I've got all the tires at 40 psi and I usually start it up once a month or so to operating temperature.
dmrock is offline
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
Human Verification
Battery tender/storage question dave1 Service, Maintenance and Technical Discussion 6 12-08-2015 07:56 AM
winter storage twhit17 Exterior Discussions 2 12-28-2010 01:33 AM
Car Storage SWGOAT Service, Maintenance and Technical Discussion 2 11-17-2010 09:20 AM
storage homegrownracing The Lounge 3 12-02-2007 07:34 PM
Storage nodog69 Service, Maintenance and Technical Discussion 1 11-17-2006 08:10 PM
