you can replace the stock TB but there is some other hardware to be changed and i believe you need to reprogram the computer because the T/C is tied into the drive by wire setup. but dont qutoe me on that, ive seen ls2 engine build ups with the Fast 90mm and i believe that is what was done. power gains are 10-15hp due to the different angle the fast is, it allows better air flow
