Old 06-01-2007, 02:23 PM   #1 (permalink)
Red Bearded Goat's Avatar
My Photos: (1)
TSB Information for 06 GTO
Automotive Recall and Technical Service Bulletin Titles for 2006 Pontiac GTO V8-6.0L VIN U. TSB information can be found on the following sight for each year GTO http://www.alldata.com/TSB/48/044818iS.html but requires a subscription for the details. The below list is for the 06. Some TSB details can be found on http://ls1gto.com/forums/showthread.php?t=16555
Hope this info helps when problems occur.
Red Beard
TSB Number & Issue Date TSB Title
02-08-98-002B JAN 07 Body - Hem Flange Repair
05-06-01-034D JAN 07 Engine - Oil Leaks From Rear Cover Assembly Area
05-07-30-018A JAN 07 A/T - Cold Weather Shift Characteristics
04-06-04-054A JAN 07 Engine Controls - Aftermarket Accessory Usage
00-03-10-006B JAN 07 Tires - Radial Force Variation (RFV) Information
99-09-40-005D DEC 06 Restraints - Availability of Seat Belt Extenders
03-07-30-007C DEC 06 A/T - Seemingly Slow 'Garage' Shifts
06-05-25-005 DEC 06 TCS - Low Traction Indicator ON With No Wheel Slip
01-06-01-011C DEC 06 Engine - Engine Oil Consumption Guideline Information
06-01-37-008 DEC 06 Cooling System - Service Replacement of Heater Hoses
02-07-30-001E DEC 06 A/T - Diagnostic Info on DTCs P0894/P1870
00-05-22-002I NOV 06 Brakes - Brake Warranty Service and Procedures
06-05-22-007 NOV 06 Brakes - Rotor/Drum Refinishing Labor Operations
06-00-89-054 NOV 06 Warranty - Claims Submission
04-06-01-029A NOV 06 Engine - Unnecessary Flushing Services
04-06-04-047G NOV 06 Fuel System - TOP TIER Detergent Gasoline
05-06-04-022C NOV 06 Fuel System - TOP TIER Detergent Gasoline Usage
06-00-89-050 NOV 06 Warranty - DTC's Required On Repair Orders
01-07-31-002B NOV 06 M/T - Hydraulic Clutch Bleeding Procedure Improvement
01-08-42-001D OCT 06 Lighting - Replacement Guidelines for Lamp Condensation
06-02-32-013 OCT 06 Power Steering - Diagnostic Tips
00-06-04-033B OCT 06 Emissions - OBDII I/M Readiness Testing
02-08-98-001C OCT 06 Body - Metal Panel Adhesive Bonding Information
00-00-89-027D OCT 06 Interior - Eliminating Unwanted Odors
04-03-10-001C OCT 06 Tires - Tread Puncture Repair Procedures
05-03-07-009A SEP 06 Wheel Alignment - Recommendations/Requirements
04-03-10-012A SEP 06 Wheels - Pitting/Brake Dust On Chrome Wheels
05-00-89-078A SEP 06 Fuel System - GM Fuel System Treatment Plus(R)
01-07-30-038D SEP 06 A/T - Poor Performance/MIL ON/DTC P0757
00-08-48-005B SEP 06 Body - Distortion On Outer Glass Surfaces
06-08-111-004 SEP 06 Body - Exterior Emblem Discoloration/Peeling/Blistering
06-08-42-007 SEP 06 Lighting - Hazard Flashers Stay ON/Won't Turn OFF
06-03-10-010 SEP 06 Wheels - Changing Procedures/Precautions
05-06-02-002A AUG 06 Cooling System - DEXCOOL(R) Leak Detection Dye
03-07-29-004C AUG 06 M/T - Normal Operating Characteristics
00-00-90-002D AUG 06 Tires - Inflation Pressure Information
06-08-50-009 AUG 06 SRS - Occupant Sensing System Precautions
03-03-10-007B AUG 06 Tires - Original Equipment Tire Characteristics
00-06-02-006D AUG 06 Cooling System - Coolant Recycling Information
06-06-04-037 AUG 06 Engine Controls - MIL Function During I/M Testing
00-03-10-002D AUG 06 Wheels Chrome Wheel Chemical Staining/Pitting/Corrosion
06-08-44-012A JUL 06 Navigation System - DVD Disc Update Program
06-01-39-007 JUL 06 A/C - Contaminated R134A Refrigerant
06-07-30-016 JUL 06 A/T - 4L60-E, 4L65-E Fluid Leak From Bell Housing Area
06-02-35-014 JUL 06 Steering - Steering Wheel Chrome Spoke Covers
06-06-04-035 JUL 06 Fuel System - E85 Fuel Usage Information
06-08-43-003 JUN 06 Windshield Wipers - Performance/Cleaning and Maintenance
99-08-51-007C JUN 06 Wheels - Aluminum Wheel Refinishing Recommendations
04-07-30-037B JUN 06 A/T - Dexron®(R) VI Fluid Availability
99-04-20-002D JUN 06 A/T - Clunk When Shifting From PARK/DRIVE/REVERSE
04-03-08-014A JUN 06 Suspension - Front End Knock Noise On Low Speed Bumps
06-08-47-003 JUN 06 Body Control Module - Security Code Location
05-06-04-035B MAY 06 Fuel System - E85 Fuel Usage Recommendations
03-07-30-043A MAY 06 A/T - Shift Lock Control Feature Function
05-08-51-008A MAY 06 Body - Bumps/Rust Colored Spots in Paint
01-07-30-042D MAY 06 A/T - 2-3/3-2 Shift Clunk Noise
06-06-04-030 MAY 06 Fuel System - E85 Refueling Station Information
04-06-04-036B MAY 06 Engine Controls - Reprogramming Warranty Coverage
06-08-45-004 MAY 06 Electrical - Instrument Panel & General Wiring Repair
06-08-44-015 APR 06 Audio System - Portable Audio Equipment Noise
06-06-01-010 APR 06 Exhaust System - Close-Coupled Cat Converter Information
05-03-10-003B APR 06 Wheels/Tires - Slow Leaks From Aluminum Wheels
05-08-64-002B APR 06 Body - Door Latches Freezes in Extreme Cold
02-08-48-001B MAR 06 Body - Urethane Adhesives for Glass Applications
05-06-03-002B MAR 06 Battery, Charging System - Electrical Diagnostics
02-06-03-009B MAR 06 Electrical - Battery Charging Tips
02-06-04-015A MAR 06 Starting System - Engine No Start/No Crank Condition
05-08-46-008A MAR 06 OnStar(R) - Language Change (Canada Only)
05-08-46-009A MAR 06 OnStar(R) - Language Change (USA Only)
06-03-10-004 MAR 06 Tires/Wheels - Wheel Weight Usage Precautions
05-08-46-004A FEB 06 OnStar(R) - Incorrect Phone Number Assigned to Vehicle
01-07-30-036F FEB 06 A/T - 4L60-E, 4L65-E, 4L70-E DTC P0756 Diagnostics
02-06-05-004B FEB 06 Accessories - DTC's P0300, P1380, P1381
04-08-46-002B FEB 06 OnStar(R) - Unable to Connect, Bulletin Cancellation
02-07-30-052D FEB 06 A/T - Fluid Cooler Flushing
06-06-04-007 FEB 06 Electrical - DTC P0606/P0689/P1516/P1682/P2176
06-06-04-006 JAN 06 Fuel System - Fuel Filler Neck Flapper Door Elimination
00-06-01-012B JAN 06 Engine - Surface Conditioning Disc Usage Prohibition
99-08-52-005B JAN 06 Keyless Entry - Operational Characteristics
04-06-04-051B JAN 06 Fuel System - Fuel Injector Maintenance Cleaning
05-09-41-010 DEC 05 SRS - New SIR System Disabling Procedure
05-03-10-020 DEC 05 Tires/Wheels - Nitrogen Gas Usage for Filling Tires
02-08-44-007B DEC 05 Audio System - Vinyl Roofs Affect Radio Performance
02-08-46-007A NOV 05 OnStar(R) - Unable To Renew Hands-Free Call Minutes
99-08-51-001A NOV 05 Body - Paint-Less Dent Repair Recommendations
02-01-39-004B NOV 05 A/C - New PAG Oil
05-00-89-072 OCT 05 Engine/Fuel System - Oil/Fuel Additive Recommendations
01-07-30-030B OCT 05 A/T - 4L60-E/4L65-E Harsh 1-2 Upshift Diagnosis
01-07-30-041B OCT 05 A/T - Diagnosing Fluid Leaks
01-07-30-010B OCT 05 A/T - Torque Converter Replacement
01-07-30-002E SEP 05 Electrical - A/T Stuck in 2nd/3rd Gear/MIL ON/DTC's
05-06-04-060 SEP 05 Engine, A/T Controls - Shared Diagnostic Trouble Codes
02-07-30-024B AUG 05 A/T - Cracked Case Diagnosis
03-06-04-012A AUG 05 Electrical - Harness Connection Inspection
05-03-08-009 JUL 05 Suspension - Unnecessary Control Arm Bushing Replacement
04-08-48-001B JUN 05 A/C - Broken Rear Window Defogger Grid Detection
89358 NOV 88 Battery - Diagnosis and Charging
Red Bearded Goat is online now   Reply With Quote
Old 06-02-2007, 12:38 AM   #2 (permalink)
koman's Avatar
Send a message via AIM to koman Send a message via MSN to koman Send a message via Yahoo to koman
funny but i never knew the 06's had an onstar option. not that i really want onstar but i never knew that.
06 impulse blue/black/ m12 1 of 252
spoilerless with dba 4000 fronts. gone
78 chevy nova 2dr sbc 400/th350/8.5 (4 jackstand mod)
92 ford rustang lx notchback 5.0/t-5/8.8 LS still stock
FMS shorties, bbk x ,fms catback, air pump overrode.
koman is offline   Reply With Quote
Old 06-02-2007, 03:22 AM   #3 (permalink)
My Photos: (451)
Here is a current list of all (25) TSBs for the 2006 GTO from the NHTSA,
Make : PONTIAC Model : GTO Year : 2006
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 3136 Date of Bulletin: MAR 02, 2007
NHTSA Item Number: 10021019
Component: POWER TRAIN:MANUAL TRANSMISSION
Get Summary
Service Bulletin Num : 030730007 Date of Bulletin: DEC 01, 2006
NHTSA Item Number: 10021103
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Get Summary
Service Bulletin Num : 060137008 Date of Bulletin: DEC 01, 2006
NHTSA Item Number: 10021105
Component: ENGINE AND ENGINE COOLING:ENGINE
Get Summary
Service Bulletin Num : 3931 Date of Bulletin: SEP 28, 2006
NHTSA Item Number: 10021018
Get Summary
Service Bulletin Num : 060842007 Date of Bulletin: SEP 01, 2006
NHTSA Item Number: 10020736
Component: EXTERIOR LIGHTING:HAZARD FLASHING WARNING LIGHTS
Get Summary
Service Bulletin Num : 040308014 Date of Bulletin: JUN 01, 2006
NHTSA Item Number: 10011196
Component: SUSPENSION
Get Summary
Service Bulletin Num : 050601034 Date of Bulletin: NOV 01, 2005
NHTSA Item Number: 10018733
Get Summary
Service Bulletin Num : 709 Date of Bulletin: SEP 01, 2005
NHTSA Item Number: 10018126
Get Summary
Service Bulletin Num : 030730007A Date of Bulletin: AUG 01, 2005
NHTSA Item Number: 10005577
Get Summary
Service Bulletin Num : 050308009 Date of Bulletin: AUG 01, 2005
NHTSA Item Number: 10017367
Get Summary
Service Bulletin Num : 3089 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10009520
Component: ELECTRICAL SYSTEM
Get Summary
Service Bulletin Num : 3136 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10010080
Get Summary
Service Bulletin Num : 3309 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10013548
Get Summary
Service Bulletin Num : 3387 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10016710
Component: POWER TRAIN:AXLE ASSEMBLY
Get Summary
Service Bulletin Num : 3332B Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10017235
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL:GAS RECIRCULATION VALVE (EGR VALVE)
Get Summary
Service Bulletin Num : 3568 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10017417
Get Summary
Service Bulletin Num : 3609A Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10018537
Get Summary
Service Bulletin Num : 3810 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10018912
Component: SERVICE BRAKES, AIR:ANTILOCK:WHEEL SPEED SENSOR
Get Summary
Service Bulletin Num : 3824 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10018921
Component: STEERING:HYDRAULIC POWER ASSIST SYSTEM
Get Summary
Service Bulletin Num : 3856 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10019192
Get Summary
Service Bulletin Num : 3940 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10019438
Component: STEERING:ELECTRIC POWER ASSIST SYSTEM
Get Summary
Service Bulletin Num : 3886 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10019446
Component: SEATS:FRONT ASSEMBLY:POWER ADJUST
Get Summary
Service Bulletin Num : 3883 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10020063
Component: ELECTRICAL SYSTEM: INSTRUMENT PANEL
Get Summary
Service Bulletin Num : 4133 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10020220
Component: STEERING:WHEEL AND HANDLE BAR
Get Summary
Service Bulletin Num : 4141 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10020224
Component: SUSPENSION:FRONT:MACPHERSON STRUT
Get Summary
Old 06-02-2007, 09:47 AM   #4 (permalink)
silversport's Avatar
no On-Star option for GTOs...
Bill
**QSM/RH/A4/17**1 of 52**
silversport is offline   Reply With Quote
Old 06-02-2007, 10:00 AM   #5 (permalink)
dizzy1
Posts: n/a
Info
what about info on the 05
