The MSRP for the front left and front right grille pieces are $73.09 and $37.08, respectively. Fred Beans, a discount OEM parts supplier, sells them for $49.60 and $25.16.
Hate to tell you, but it sounds like your dealer installed your SAP grille incorrectly. To do the job right, you need to remove the front bumper. Sounds like they busted your OEM grille out -- then shoved the SAP into place. I've heard of other dealers doing this.
I'd stop by and talk to the service manager:
Find out how they installed the SAP grilles. They should be held in place by a series of razor blade things that slide onto the grille's tabs. You might be able to see them by looking through the hood latch hole. If they're not there, you're going to have to go to a body shop (NOT this dealer's) and have them done right. If the tabs aren't there -- be damn sure you get them from the dealer.
If the service manager starts acting like a jerk (oh, it looks fine -- you don't need those tabs, the Elmer's glue we used is perfectly safe), then got after them for a set of replacement grilles. Again, if they did the job right, there is ABSOLUTELY POSITIVELY NO WAY the grilles can get broken. You just lift the razor blade things off with a pair of pliers -- and the grilles push out.
Hope that helps.
