05 TSB's
Here is a summary of all the 05 TSB's........
Make : PONTIAC Model : GTO Year : 2005
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 040601025 Date of Bulletin: MAR 01, 2005
NHTSA Item Number: 10011204
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
EXCHANGE PROGRAM FOR 2005 MODEL YEAR ENGINES. *TT UPDATE. *TT
Service Bulletin Num : 03012005 Date of Bulletin: MAR 01, 2005
NHTSA Item Number: 10014871
Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
Summary:
NO AUDIO CONDITION FROM THE RADIO. *EH
Service Bulletin Num : 050851001 Date of Bulletin: MAR 01, 2005
NHTSA Item Number: 10015029
Component: STRUCTURE:BODY
Summary:
PAINT STAIN UNDER PROTECTIVE SHIPPING FILM. *TT
Service Bulletin Num : 040310013 Date of Bulletin: OCT 01, 2004
NHTSA Item Number: 10011058
Component: SUSPENSION
Summary:
DRIVING CHARACTERISTICS OF REAR-WHEEL DRIVE AND AVAILABLE WINTER TIRES. ALSO INCLUDES THE 2004-2005 CADILLAC CTS-V. *TT
Service Bulletin Num : 09072004 Date of Bulletin: SEP 07, 2004
NHTSA Item Number: 10013191
Summary:
PAINT PEELING FROM THE FRONT OR REAR FASCIAS. *EH
Service Bulletin Num : 040603006 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10011040
Summary:
PROPER JUMP STARTING PROCEDURE. *TT
Service Bulletin Num : 0804 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10014346
Summary:
OIL LIFE SYSTEM RESET PROCEDURES - CARS. *NM
Service Bulletin Num : 3235 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10011720
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
ENGINEERING INVESTIGATION ON THE NEW TRANSMISSION CONTROL MODULE. *EH
Service Bulletin Num : 3438 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10014874
Component: ELECTRICAL SYSTEM
Summary:
HEADLAMPS STAY ON WHEN HEADLAMP SWITCH IN AUTO MODE WHICH MAY CAUSE THE BATTERY TO GO DEAD. *TT
Service Bulletin Num : 3335 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10014879
Summary:
INVESTIGATION OF PUMP AREA LEAKS. *TT
Service Bulletin Num : 3363 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10014880
Summary:
4L60E/4L65E NO REVERSE. *TT
Service Bulletin Num : 3369 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10014907
Summary:
TO BETTER UNDERSTAND SPRAG DAMAGE AN ENGINEERING INVESTIGATION IS BEING CONDUCTED. TYPICAL SYMPTOMS INCLUDE NO FORWARD MOVEMENT IN D4 OR D3 SHIFT LEVER POSITION. MOVEMENT CAN BE OBTAINED IN D2, D1 OR REVERSE. *TT
