2005 GTO Dead? - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 12-09-2012, 10:47 AM   #1 (permalink)
2005 GTO Dead?
My 05 GTO has been sitting for almost a month while I have been installing UPP twin turbos. Well got to the point last night where I needed to fire it up to finish adding coolant/water and check.oil level. Battery was relocated to trunk due to lack of engine bay room with 0 gauge wire. Put key in and turned and dash would dim when key turned. Figured battery was weak (6 yr old optima) so I attempted to jump start it with same results. So I took battery to Advanced where they checked it. Came up unstable/bad cell. So I bought new one and took it home and installed. Now here is what is happening;
Interior dome and door and under dash lights work
Key fob when clicked lock/unlock parking lights flash but locks don't operate
Put key in ignition and turn nothing happens.... I mean nothing dash doesn't even light up or radio power up. Only light in cluster that is lite is the car/lock red flashing icon. Has me baffled. I have rechecked ground connection (frame sanded to bare metal).
Any suggestions or ideas?
I have checked ALL dash/engine bay fuses... all good.
I am completely baffled.
grifter95 is offline   Reply With Quote
Old 12-09-2012, 01:49 PM   #2 (permalink)
Rechecked all fuses this morning in the light... none are blown. Headlights, interior dome/door lights, parking lights all work. But nothing anywhere else (pwr seats,windows, mirrors). Putting in the key doss not cause the usual chimming when doors are open, and turning it does not cause instrument cluster to wake up or radio/clock to illuminate.
Could the computer be fried? Could the old battery having bad cell/unstable caused all of this? Seems if it had been a short some fuse would be blown.
Checked voltage at battery (12.66v) and at fuse box (12.38v) doesn't seem to be lack.of power.
Thought it might be antheft being stupid and went to check with HP tuners but must have ignition tuned on for HP to read and turning key obviously doesn't cause ignition to come on now.
Bad ignition switch? Bad computer? Short somewhere? Second bad battery? Anyone?
Old 12-09-2012, 07:18 PM   #3 (permalink)
jmt455's Avatar
Dumb question, but is the new battery fully charged?
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline   Reply With Quote
Old 12-09-2012, 09:22 PM   #4 (permalink)
I assume it did come fully charged. I checked its voltage and it was 12v+. Also charged it with 10 amps for 20-30 minutes with no change in results. How else should I check to make sure it is battery?
Old 12-09-2012, 09:26 PM   #5 (permalink)
Opened car tonight and all hazard lights, interior lights (except dash), and horns flashed until clicker on key fob was clicked unlock. So plenty is still working.... just nothing tied to ignition being switched on. My tuner friend thinks it could be a bad bcm? Maybe shorted when bad battery was misfiring? But he is only guessing. Would power seats usually work with key turned off? I would think so... but they are not working.
Still baffled... feeling helpless.
Old 12-09-2012, 09:56 PM   #6 (permalink)
68OldGoat's Avatar
Check out the Sticky on this site for a possible easy fix for the BCM Wiring harness...common problem with these cars. IMO I believe it has something to do with the BCM like your tuner buddy.
68OldGoat is offline   Reply With Quote
Old 12-09-2012, 09:57 PM   #7 (permalink)
Odd that relay audibly clicks when fob is pressed but actual locks do nothing?
Old 12-09-2012, 09:58 PM   #8 (permalink)
68OldGoat.... still new to this forum. Where would I find the sticky you suggested?
Old 12-09-2012, 09:59 PM   #9 (permalink)
johni53's Avatar
My Photos: (5)
I'd take it to a GM dealer; know it'll be more expensive but at least you've got a better chance for the right diagnosis.
johni53 is offline   Reply With Quote
Old 12-09-2012, 10:01 PM   #10 (permalink)
68OldGoat's Avatar
Service, Maintenance and Technical Discussion - Pontiac GTO Forum
Not Dead injn37 1964-1974 GTO General Discussion 2 11-05-2010 12:19 PM
2005 GOAT, Modded, Gets dead battery every 3-4 weeks MJMALLEO 2004-2006 GTO General Discussion 3 10-05-2010 07:03 AM
Top Dead Center 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical Discussions 6 06-13-2010 11:36 AM
Dead Battery Tom Rice 2004-2006 GTO General Discussion 9 02-21-2008 12:39 PM
Dead Pedal Joey Waid 2004-2006 GTO General Discussion 4 01-14-2005 09:16 PM
SEO by vBSEO 3.3.2
