The best way to prevent this situation is to use the switch manually. It happened to me yesterday for the 1st time as I rolled up the driveway turning the car off as I was still moving, pulled the key out and opened the door in one rapid motion in conjunction with setting the parking brake... bolted into the house, got what I needed and returned to find my lights still on. Using the remote to lock or unlock did nothing. I turned the lights off manually, started the car and drove away. While driving down my street I put the switch back to auto. Upon stopping and getting out again after shutting down the normal way I do it the auto lights worked properly.
Just a quirk to remember if your in a rush and you shut down while moving or open the door before removing the key and you have the headlight switch on auto.
 Enjoy rug burn, support lap dancing!
