As the last post said, slide your fingers as much as possible, then with a bit more pressure, the clips pop. But DON'T try lifting the console from the back waiting for it to pop, because you'd break it first.
There're 2 clips right where the window switches are, and another 2 where the shifter boot starts. You'll have to remove the rubber 'tray' below the ashtray so the console slips out easier. And remember about the only screw around that area, as mentioned. Good luck.
JC
