CAI insulation wrap
Does anyone use insulation wrap on their Cold Air or Stock intake tubes. I have been doing this for a long time to help reduce hot air from entering the tube . For a long time I was buying a automotive type insulation wrap till I came across something that is better, cheaper and easy to install. I purchased a set of HEAT SLEEVES. These are protective sleeves that shops and factory workers use to protect their arms from hot objects. They are rated anywhere from 250 to 500 degrees. You just purchase a pair and slide them right over your intake tubes. It cuts down the amount of heat that hits your tube from items like your radiator and water hoses. It does work and works well. Try it
