Clunking/grinding when turning - Pontiac GTO Forum
post #1 of 12 (permalink) Old 01-05-2009, 08:57 PM Thread Starter
Michael.Narlock's Avatar
So My gto makes a kind of clunking/grinding noise when i turn to the right at very low speed/rpm's...Doest do it when im going above 10mph but say i try to pull into a parking spot it does it. Im wondering maybe upper strut baring?
Michael.Narlock is offline
post #2 of 12 (permalink) Old 01-05-2009, 10:00 PM
cncmasterofor's Avatar
It very well could be the strut bushings/bearings. Strut bushings, rear springs and the front radius rod bushings are almost always bad from the dealer.
What part of OR are you from?
cncmasterofor is offline
post #3 of 12 (permalink) Old 01-06-2009, 08:44 AM
Quoted: 20 Post(s)
Will it do it on flat level ground??
post #4 of 12 (permalink) Old 01-06-2009, 10:07 PM Thread Starter
Im from newberg and yes it will do it on flat ground. But only at very low speeds and rarely when im stationary
post #5 of 12 (permalink) Old 01-07-2009, 08:21 AM
Quoted: 20 Post(s)
Are you sure the noise is coming from the front?
post #6 of 12 (permalink) Old 01-07-2009, 12:26 PM
2006BlueGoat's Avatar
My '06 did that from new. I took it back to the dealer and they had a service bulletin relating to improper spring install at the factory. If that is the same problem you're having it might be a warranty fix.
2006BlueGoat is offline
post #7 of 12 (permalink) Old 01-07-2009, 10:26 PM Thread Starter
Ya its from the front. And im almost sure that it is infact either the right upper strut or the spring itself. ill take it back to the dealer and find out.
post #8 of 12 (permalink) Old 01-08-2009, 08:34 AM
Quoted: 11 Post(s)
Tie Rod end A Arm Bushings, steering rack come to mind. Was the car in an accident previous?
President: Susquehanna Valley GTO Inc.
president@svgto.com
Public Relations Coordinator: GTOAA
publicrelations@gtoaa.org
GTO JUDGE is online now
post #9 of 12 (permalink) Old 01-11-2009, 09:27 PM Thread Starter
naw damn things clean. I just want to fix it but it seems to me that every part that i replace isnt the damn thing and its no the tires rubbing either...im friggin stumped
post #10 of 12 (permalink) Old 01-13-2009, 03:47 PM
Quoted: 11 Post(s)
Maybe the strut leaked and although not completely dry pressure is causing it to thump when you turn? Maybe something is bent?
president@svgto.com
Human Verification
Chirping Noise When Turning Left?! kdkiernan Drive train, suspension, alignment and brakes. 16 10-16-2009 07:51 PM
turning off O2 engine light errors cjsuttonx Engine Discussions 13 05-27-2008 04:15 PM
turning off speed/volume regulator on 04 stock radio? cjsuttonx Interior Discussions 8 05-03-2008 07:57 AM
Not smooth when turning the ignition key PatrickNJ 2004-2006 GTO General Discussion 12 10-08-2007 06:32 AM
Knock when turning left mtullo Service, Maintenance and Technical Discussion 4 09-23-2006 12:50 PM
