Old 06-09-2008, 02:22 PM   #11 (permalink)
Originally Posted by 6QTS11OZ View Post
. Here are some instructions from another forum.
Clutch and Flywheel Install
Hope this helps.
First of all, many thanks to everyone who posted their wisdom. The clutch replacement was a success and I'm back on the road. The instructions listed above were extremely useful, especially the torque specifications.
You were correct, the slave cylinder was shot. As it turns out, the throwout bearing failed and took the slave cylinder with it.
As I mentioned earlier, I used the Perfection Clutch Set from Advance. It had everything I needed with the exception of the slave. It came with a flywheel, pressure plate, clutch disk, pilot bearing and alignment tool. Quality looked to be very good (at least as good as the original). Around $400. Slave cost another $90.
Some things I learned along the way:
I didn't drop the exhaust and marked/disconnected the drive shaft from the transmission. If you take out the 2 bolts holding the carrier bearing, it gives you room to pull the shaft out and leave the yoke in place. (this keeps the transmission oil in place throughout the replacement). I bungied the drive shaft up and out of the way.
The posters were correct, I don't see how it would be possible to get the transmission out/in by just disconnecting the bellhousing from the engine. The 2 upper transmission bolts were easy once we fastened about 6 extensions together and used the ratchet in the blank area behind the yoke. The natural play in the extensions allows it to curve around the transmission and still gives you plenty of torque.
The shifter DEFINITELY needs to be in 3rd gear position. A transmission jack aids greatly in the reassembly and was able to get it in myself (bad shoulder and all). I think you risk too much trying to use a floor jack.
At any rate, my undying gratitude and thanks to all for your help. Great forum!
hcpcjj is offline   Reply With Quote
Old 06-10-2008, 01:27 PM   #12 (permalink)
6QTS11OZ's Avatar
Location: Where the women are scarce and the sheep are scared.
My Photos: (16)
Glad I could help.
~I'm ya huckleberry~
516/500 2-da-rears.
http://media.putfile.com/GTO-Maggie-dyno-run
6QTS11OZ is offline   Reply With Quote
Old 06-10-2008, 01:54 PM   #13 (permalink)
Moderator
My Photos: (16)
hcpcjj, you didn`t have to remove the shifter? Just put it in 3rd and the tranny came out and back in with it attached?
Old 06-10-2008, 04:49 PM   #14 (permalink)
I don't think it would fit through the white plastic cover.
Old 07-06-2008, 03:03 PM   #15 (permalink)
1/4 mile = 12.505 @ 112.07
My Photos: (2)
I ended up buying the Perfection clutch kit (Flywheel, plate, disk, pilot bearin & release bearing, lifetime warranty). I plan to keep the car all original with no mods. Based on the amount of noise & burning smell, I'd say that the release bearing failed and the pressure plate is toast. With 47K I might as well replace it anyway.
good luck on that warranty. i haven't seen too many clutches regardless of manufacturer (or in most cases repackager) actually warrant a clutch unless it just falls apart and they're in a great mood that day. glad to hear you got it all on the road again tho. in my case taking the exhaust off is quick and painless and IMHO makes the trans job a lot easier. i've had that sucker off 5 times now.
12.39 ET, 112.73 MPH
1.819 60ft
SS Intake|!MAF|HP Tuners|SLP LTs|FTI cam|SLP UD|BBK 80mm TB|2.5" Exh
Rip Shift|DiffTechshaft|Diamond Stg3 clutch|BFG DRs|Lovells springs|Koni|Harrop cover|SuperPro bushes|Hotchkis sways|3.91s
svede1212 is offline   Reply With Quote
Old 07-30-2008, 03:08 PM   #16 (permalink)
Per the instructions - un-bolt the white cover before removing the trans.
Buying a GTO, What's up with the Clutch? apicia 2004-2006 GTO General Discussion 9 03-12-2007 05:57 PM
Clutch Extension GTO_Gregory Interior Discussions 4 10-28-2006 08:31 PM
Clutch Problems GoatBoy37 Service, Maintenance and Technical Discussion 4 08-26-2006 12:06 AM
Clunk when Lifting Clutch daveinsa 2004-2006 GTO General Discussion 6 06-17-2005 08:53 AM
Squeaky Clutch Pedal Fix b_a_betterperson Service, Maintenance and Technical Discussion 1 06-07-2005 09:40 AM
