Distribution Updates
Here is the GTO Update that includes the 18" wheel pkg. No pictue of the wheel as of yet.
Updates for GTO
Week of 1/17/2005
Effective 1/17/2005, the following changes will be made to the Vehicle Order Guide:
Exterior section-Added (QUG) Tires, P235/40ZR18, summer-only. It is "A" on GTO.
Exterior section-Added (N87) Wheels, 18" (45.7 cm) aluminum, 5-spoke. It is "A" on GTO.
Week of 1/10/2005
Effective 1/10/2005, the following changes will be made to the Vehicle Order Guide:
Mechanical section-(LS2) Engine, 6.0L V8 SFI aluminum, changed description to read "(400 HP [297.9 kW] @ 5200 rpm, 400 lb.-ft. [546.7 N-m] @ 4000 rpm)
Week of 11/22/2004
Effective 11/22/2004, the following changes will be made to the Vehicle Order Guide:
Mechanical section-(R8E) Gas guzzler tax, changed footnote 1 to read "Included and only available with (MX0) Transmission, 4-speed automatic.".
Week of 10/25/2004
Effective 10/25/2004, the following changes will be made to the Vehicle Order Guide:
Exterior section-Deleted (NBB) Regular production accessory, Phantom Black Sport Appearance Package entirely.
Exterior section-Deleted (NBC) Regular production accessory, Quicksilver Metallic Sport Appearance Package entirely.
Exterior section-Deleted (NBA) Regular production accessory, Torrid Red Sport Appearance Package entirely.
Week of 9/13/2004
Effective 9/13/2004, the following changes will be made to the Vehicle Order Guide:
Exterior section-Deleted (QUG) Tires, P235/40ZR18, summer only tire entirely.
Exterior section-Deleted (N87) Wheels, 18" x 8" (43.2 cm), 5-spoke aluminum entirely.
Week of 8/16/2004
Effective 8/16/2004, the following changes will be made to the Vehicle Order Guide:
Exterior section-Deleted (QV6) Tires, P235/40ZR18, summer only tire, blackwall entirely.
Exterior section-Added (QUG) Tires, P235/40ZR18, summer only tire, blackwall as an available option.
Exterior section-(N87) Wheels, 18" x 8" (43.2 cm), 5-spoke aluminum, added footnote 1, which reads "Not available for ordering until November 2004 production."
Week of 8/9/2004
Effective 8/9/2004, the following changes will be made to the Vehicle Order Guide:
Exterior section-Changed description of "Exhaust outlets" to read "Exhaust outlets, spilt dual with single chrome-tipped outlets".
Exterior section-Added "Hood scoops" as standard equipment.
Exterior section-Added (BZJ) Hood scoop delete as an available option.
Exterior section-Added (NBB) Regular production accessory, Phantom Black Sport Appearance Package, includes front fascia extensions, side rocker moldings, rear fascia extensions with custom dual/dual exhaust tips, unique spoiler and grille insert (SPO-supplied, dealer-installed). It is available with footnote 1, which reads "Requires exterior color (80U) Phantom Black.".
Exterior section-Added (NBC) Regular production accessory, Quicksilver Metallic Sport Appearance Package, includes front fascia extensions, side rocker moldings, rear fascia extensions with custom dual/dual exhaust tips, unique spoiler and grille insert (SPO-supplied, dealer-installed). It is available with footnote 1, which reads "Requires exterior color (13U) Quicksilver Metallic.".
Exterior section-Added (NBA) Regular production accessory, Torrid Red Sport Appearance Package, includes front fascia extensions, side rocker moldings, rear fascia extensions with custom dual/dual exhaust tips, unique spoiler and grille insert (SPO-supplied, dealer-installed). It is available with footnote 1, which reads "Requires exterior color (62U) Torrid Red.".
Exterior section-Added (QV6) Tires, P235/40ZR18, summer only tire, blackwall as an available option.
Exterior section-Added (N87) Wheels, 18" x 8" (43.2 cm), 5-spoke aluminum as an available option.
Mechanical section-Added "Brakes, performance brake package with Red calipers" as standard equipment.
Mechanical section-Deleted (LS1) Engine, 5.7L V8 SFI aluminum entirely.
Mechanical section-Added (LS2) Engine, 6.0L V8 SFI aluminum (400 HP [297.9 kW] @ 5200 rpm, 395 lb.-ft. [539.9 N-m] @ 4000 rpm) as standard equipment.
Color and Trim section-Revised footnote 3 to read "The standard interior color offered on GTO is (812) Black. However, (746) Blue and (756) Red can be substituted at no additional cost (see chart above for specific color compatibility)."
Trailering Specs section-Changed engine description to read "(LS2) 6.0L V8 SFI".
Week of 8/2/2004
Effective 8/2/2004, the following changes will be made to the Vehicle Order Guide:
Color and Trim section-Added (12U) Cyclone Gray Metallic as available "A" with interior color (812) Black with footnote 3 applying. Also, the Gauge Color and the Color Stitching is Gray.
Color and Trim section-Added (28U) Midnight Blue Metallic as available with interior color (812) Black with footnote 3 applying. Also, the Gauge Color and the Color Stitching is Gray.
Color and Trim section-Deleted exterior color (47U) Barbados Blue Metallic entirely.
Color and Trim section-Deleted exterior color (72U) Cosmos Purple Metallic entirely.
Week of 5/3/2004
Effective 5/3/2004, the following changes will be made to the Vehicle Order Guide:
Trailering section-2005 information is now available, please review the order guide for details.
2006 Torrid Red/Red M6
