does a 3k stall require a tune? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-14-2017, 07:45 PM Thread Starter
rednblackgoat's Avatar
getting a thousand different answered when doing a search but Im getting a trans rebuilt (4L60E) in an 04 GTO and im going with a 3,000 stall circle D converter because the tourqer 2 cam recommends a 3k or higher but my question is will i have to trailer the car home after a stall install as I was told or is that incorrect? i was told a tune must be done before driving it or it would burn the converter up.
rednblackgoat is offline
post #2 of 3 (permalink) Old 06-15-2017, 10:28 AM
GTO44's Avatar
Quoted: 27 Post(s)
No you won't burn the converter up. You'll be fine driving it around.
The worse thing that will happen is you might end up in limp mode if the computer thinks your trans is slipping from the stall. The computer calls it a "non shift". When it commands a shift it looks for rpm drop. If it doesn't happen enough to satisfy the computer it may throw an SES light and possibly disable some functions of the trans like converter lock up. This is easily reset by turning the key off. Or You can tune this function out.
But that usually won't happen with anything under 3,500 stall. There are plenty of people that run a 3,000 stall with no tune.
Besides turning that limp mode feature off, the only thing a tuning for a converter does is dial in the shift point and times.
So i'd say, let er rip tater chip
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
post #3 of 3 (permalink) Old 06-16-2017, 08:06 PM Thread Starter
ok,will a truck converter work? i bought a 3k stall from a buddy but its a 278mm LS style converter
Human Verification
Desired Look/Require Suspension Changes? 2thGuardian 1964-1974 Tempest, Lemans & GTO General Discussion 13 08-04-2015 10:11 AM
Diablo Tune or 91 0ct Tune? Bossin Engine Tuning 12 06-07-2013 05:09 PM
Which Stereo does not require dash mods? mbergin 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 6 02-02-2013 05:27 AM
Do ram-air manifolds require donut gaskets jimchevy 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 02-26-2012 07:18 PM
