Old 04-16-2008, 06:16 PM   #1 (permalink)
YeloTXGoat38's Avatar
Getting Tired of the Problems...Need Advice
Ok, so I posted this on LS1GTO also, but I want opinions:
OK, here is a list of all of the problems (that I can remember) I have had since I bought my car in early 2006:
1. On third clutch
2. Transmission replaced
3. Parking Brake broke
4. Driver's side seat back fell off
5. Driver's side door lock broke
6. Bell housing leak (caused first clutch replacement)
7. Rear main seal leak (caused second clutch replacement)
8. Water pump replaced
9. Rear end locker/posi trac replacement (currently in shop for this)
10.Steering wheel controls go out of whack from time to time (have just put up with this)
11. Shifter broke off
Okay......I've never even taken my car to the track. I get on it once in a while, other than that I've babied the car. I am the third owner, I found out from Carfax, when I bought it at 21,000 miles . I think that the second owner was just the dealer that sold it at an auction. The car was immaculate when I bought it and the engine is very strong.
Do I have any argument lemon-wise, since it hasn't been repeat issues?
I have the 100,000 extended warranty, thank God, but I'm upside down bigtime on my car, and it has 59K+ miles on it. I love it when it isn't in the shop, which is about every other month. Would you trade it in? I'm shopping around.
You know, I've put so much into this car, too, it's killing me. It's becoming a liability to me, though, you know?
Yellowjacket 04M6
Cosmetic: Tint, "Angry Goat" Graphic, wing delete, TSW Thruxtons, staggered
Performance: KN Filter, Superchips Tune, Pedders, Koni's, Hotchkiss, Kumho Ecsta SPT's, Spec Stage II Clutch
YeloTXGoat38 is offline   Reply With Quote
Old 04-16-2008, 06:21 PM   #2 (permalink)
Moderator
My Photos: (16)
As far as I know, you have to take it in three times for the same repair, and after three times if the same problem is still a problem, then the lemon law comes into play.
Old 04-16-2008, 06:37 PM   #3 (permalink)
fergyflyer's Avatar
Rukee is exactly right, 3 times for the same issue, then it has to cause you problems a 4th time in most states.
You either just got a bad one, or the guy that owned it before you thrashed it.
if your upside down, your pretty much stuck and should thank God you have the warranty. Wait till your close to not being upside down, usually the 3rd year of ownership if you financed the whole amount, to do anything, or you'll just carryover the negative equity into a deeper hole.
Good luck.
fergyflyer is offline   Reply With Quote
Old 04-16-2008, 07:02 PM   #4 (permalink)
My Photos: (46)
Each state has different guidelines. For the most part the lemon law is only good on new cars, but some states will recognize used cars, it depends on your state. You are a 3rd owner though. READ BELOW
IMO the previous owner(s) had problems and dumped it. Now it's your problem and your turn to dump it.
I would recommend a vin check through a dealer to see what if any warranty claims were made, and corrected.
Try this link, you can get FREE advise from a lemon law atty.
Your Free Lemon Case Review - Kahn & Associates, L.L.C.
Here is a link state by state. Lemon Law America
Here is a generic overview of the Lemon Law:
Lemon Law Information
Lemon Law Guides
State Lemon Law Statutes
Think your Car is a Lemon? Your State may agree, but maybe not to your liking. See how your State defines what a Lemon is and if your Car and its Repair History qualify.
Nearly all State Lemon Law Statutes are similar to the Federal Magnuson-Moss Warranty Act which makes breach of warranty a violation of federal law. All States have enacted their own Warranty Acts and many States have enacted specific Statutes that pertain to Automobile Warranties. If your car is not considered a "lemon" in your State, you do have other recourses.
Lemon Law Summaries - Lemon Law Summaries for each State.
Lemon Law Statutes - Lemon Law Statutes for each State.
What is a Lemon?
A vehicle that continues to have a defect that substantially impairs its use, value, or safety. Generally, if the car has been repaired 4 or more times for the same Defect within the Warranty Period and the Defect has not been fixed, the car qualifies as a Lemon. All States differ so you should consult the Lemon Law Summary and the State Statutes for your particular State. Note that the warranty period may or may not coincide with the Manufacturer's Warranty.
Do I have a Lemon?
If the paint is peeling, the light switch came out when you pulled on it, the car makes "funny noises" but otherwise drives just fine, or you found 10 things you don't like about your new car but none of them prevent you from driving it, then No, you do not have a Lemon.
If the brakes don't work, the car won't go into reverse gear, the darn thing won't start on cold mornings or hot afternoons, the rear door opens all by itself, the driver's seat wobbles, or the car chugs along at 30 mph when it should be going 50 mph, then Yes, you may have a Lemon. Providing you've given the manufacturer an opportunity to repair the defect.
In most States, 10 different defects during the Warranty Period does not brand the car as a Lemon. In some States, a single defect that might cause Serious Injury makes your car a Lemon if the manufacturer cannot fix the problem within 1 attempt.
You may have a Lemon, but if you do nothing to protect your Consumer Rights, such as documenting your Repairs and allowing the Manufacturer a chance to fix the problem(s), you lose all rights under the various State Warranty Acts.
Do I need a Lawyer?
The answer depends upon which State you Purchased or Registered your car in. In some States and with proper documentation, you simply file a Complaint. In other States, you will need to hire an Attorney.
Who pays the Lawyer?
Only about half of the States allow you to recover Attorney Fees. If your Attorney sues under the Magnuson-Moss Warranty Act, you will be awarded Attorney Fees if you win. Note that an Attorney's Fee is based upon actual time expended rather than being tied to any percentage of the recovery. In some States, you must pay the manufacturer's Attorney Fees if you lose.
Is a Used or Leased Car protected?
It depends upon which State the car was purchased or leased in. Some states include used and leased cars in their Lemon Law statutes. Some states have separate laws for used vehicles. Some states provide protection only for new cars. In some states, even the Attorney General is unable to tell you if a Leased vehicle is covered due to the way the law is phrased and you will be referred to an Attorney for clarification of the law. See the Lemon Law Summary and the State Statutes for your particular State to determine what is covered.
What about Motor Homes and Motorcycles?
Most States cover the drive train portion of Motor Homes (that part which is not used for dwelling purposes). Motorcycles are generally not covered but a few states do include them in their lemon law statutes.
If you have a defective Motorcycle, Motor Home, used car, leased car, or a car used for business purposes and your State Lemon Law does not cover these vehicles, you still have other recourses such as the Uniform Commercial Code and the Federal Magnuson-Moss Warranty Act (providing you were given a written warranty). Consult with an Attorney that specializes in this area.
Tips to Protect your Investment
* Often times, your new car isn't suspected of being a Lemon until it is too late (out of warranty, over the mileage limit, etc). If you keep a record of every repair visit, starting with the first one, you will protect your rights under Consumer Laws. Our Repair Log makes it easy to record every Repair Attempt.
* Document everything! This includes notes, who you talk to, what is said, dates and times. Put your complaints in writing and keep a copy for yourself. Be sure to obtain a copy of any Warranty Repair Orders. Demand a copy if necessary and if the dealer will not give you one, be sure to document the fact. When you pick up your car, obtain an Invoice. The dealer may claim that you are not entitled to an Invoice because there were no charges (you were not invoiced for any repairs). It is up to you to prove repair attempts! The final Invoice shows what was or was not repaired.
* Make absolutely sure the dealer records your complaint on the Repair Order exactly as you describe it. You must make sure to describe the defect exactly the same on each repair visit or you may forfeit your rights under the "reasonable attempts to repair for the same defect" clause.
* Be sure that the date, time in, and odometer reading are recorded as well as the date and time you picked up the car. In most States you are covered by the Lemon Law if the vehicle has been in the repair shop for an accumulative number of days during the coverage period.
* If your car fails in the middle of the desert or in the middle lane of rush hour freeway traffic, record the date and time, the amount of time you had to wait for assistance, whether or not you had to rent a car, and your general overall feelings. The emotional trauma dealing with a defective vehicle has a lot of bearing on your case should you need to go to arbitration or court.
Vice President : SVGTO Tigers
Member
GTO JUDGE is offline   Reply With Quote
Old 04-16-2008, 07:11 PM   #5 (permalink)
My Photos: (46)
Texas Lemon Law Statutes
Here is Texas's L.L.
Member
Old 04-16-2008, 08:13 PM   #6 (permalink)
Thanks for the help, appreciate it. I'm torn between trading it in, or sucking it up, putting up with the repairs, and paying more or all of it off.
Thing is I'm retiring from the Army in August, and moving out to MA to be with my gf. With gas prices and all, having to look for a job, an economical and reliable car is looking better and better to me.
Yellowjacket 04M6
Old 04-17-2008, 07:43 AM   #7 (permalink)
My Photos: (46)
IMO....If I were having the problems you are having, I'd dump it. That's what the previous owners did.
Once you get to MA and get the GTO bug again, there will be others, most likely with a lot less hassles than you are having now.
Good Luck
Member
Old 04-17-2008, 08:30 AM   #8 (permalink)
Wow, that really sucks, I feel for you... It seems very obvious that a previous owner was EXTREMELY HARD on your car... But you may be getting toward the end of the damage, and with a fresh driveline from the clutch-on-back, many many miles of trouble-free driving...
I bought my '06 M6 with 9,000 miles on it.... From a 65 year old retired dentist... I've had no problems.
69bossnine is offline   Reply With Quote
Old 04-18-2008, 09:03 PM   #9 (permalink)
Yeah, I have thought the same thing - that with a mostly fresh driveline now in place, it may be good for quite a while, now. I may consider giving it one more try, then give it up.
I have an emotional attachment, to it, which I'm sure many of you can relate to....it's hard to let go of.
Yellowjacket 04M6
Old 04-18-2008, 10:17 PM   #10 (permalink)
fergyflyer's Avatar
I had this 2002 Z06 that I bought used, 2 owners and low miles on it in 2004. I had that thing to the dealer once a week for the 3 months straight for all kinds of problems. Even though the car was out of warranty, the dealer felt bad for me and got GM to agree that most of the problems shouldn't have happened.
I gave up when I started having electrical problems that came and went. I always wondered, did I quit too early. Were the fuel guage and door controls the last problems or was it never going to stop. I checked Carfax about a month ago. The guy that bought it still has it. There is a total of 4 entries on the car since I sold it 3 years ago. The guy has been to the dealer for service with problems 4 times and put 30,000 miles on it.
Still don't know for sure though, he may have fixed some of the problems himself or at a repair place that doesn't report to Carfax.
dealers informed me of major problems.. muscleT 2004-2006 GTO General Discussion 3 03-06-2008 12:00 PM
Thinking of buying a GTO Need some advice chargerfan09 Service, Maintenance and Technical Discussion 2 09-25-2007 07:39 AM
Those w/ problems w/ GTO BostonF4$ 2004-2006 GTO General Discussion 10 07-10-2006 08:21 AM
comparison the "cant break 8s" b4 advice and after the advice DK2F Service, Maintenance and Technical Discussion 0 02-11-2006 03:09 AM
clutch problems?????? jag767 Service, Maintenance and Technical Discussion 16 03-11-2005 11:21 AM
