Originally Posted by DanielFinzel
Hello all!
Im currently new to this forum so my browsing capabilities are not the best yet so i apologize if this has been answered before.
I own a 2004 GTO and just ordered HID's from a website that was recomended on this forum. I was looking through my owners manual on headlamp removal and it was not very descriptive. It tells me to remove the battery completely (is this really necessary?). I also went and looked at my car and saw one bolt that looks to be holding the headlamp in place. However i doubt thats the case. So i read on in the manual and it says i need to remove radiator cover and the four screws holding it in.
So right now im kinda sitting here wondering if this is gonna take forever to do and debating on paying to have it done for me.  SO...Does anyone have any pictures or advice on headlamp removal that would make putting the hid kit in for one easier and for another cheaper?
Thanks,
Daniel
Here is a pic i took BTW
and another....
Hey Daniel,
The HID installation is really not that hard, but, it is much easier if you remove the headlamps from the car.
You do not have to take the battery out to remove the headlamp. Use an extension on a rachet with a 10mm socket to get the retaining bolt for the passenger side lamp. There are also two bolts underneath each lamp, that will require you to remove the front bumper cover. This may sound intimidating, but it's pretty easy. The front bumper cover his held on by 7 screws. Two each in the leading edge of each front wheel opening, and three across the top on, under the hood.
Go to LS1gto.com and do a search for "front bumper removal" and it gives you detailed instructions on how it's done.
Removing the headlamps, the radiator shroud and the front bumper cover will make for a very smooth installation.
The HID kits are "esentially" plug and play, but I found the kit plug to not fit securely into the factory harness, so I opted to hard wire mine, and have had no trouble with it. I did my lows and fogs at the same time.
Email or PM me if you need anymore help.
Russ
