how fast in 2nd gear - Pontiac GTO Forum
post #1 of 15 (permalink) Old 09-23-2008, 11:44 AM Thread Starter
I'm looking to buy a 2006 GTO and was wanting to know how fast will it go in 2nd gear before you need to shift?
wesjenn is offline
post #2 of 15 (permalink) Old 09-23-2008, 11:48 AM
Quoted: 11 Post(s)
Welcome to the Forum....
Red line is 6500 RPM. How Fast? I'd not go past red line.
Below is taken from the manual.
Manual Transmission Recommended
Shift Speeds
1 to 2
16 mph
(25 km/h)
2 to 3
22 mph
(35 km/h)
3 to 4
30 mph
(48 km/h)
4 to 5
40 mph
(65 km/h)
5 to 6
50 mph
(80 km/h)
If your speed drops below 20 mph (32 km/h), or if the
engine is not running smoothly, you should downshift to
the next lower gear.
One to Four Shift Light
(Manual Transmission)
When this light comes on, you can only shift from
FIRST (1) to FOURTH (4) instead of FIRST (1) to
SECOND (2). The light will be displayed on the
instrument panel cluster and a message will be
displayed on the trip computer.
You must complete the shift into FOURTH (4) to turn
off this feature. This helps you get the best possible
fuel economy.
Downshifting
If you skip a gear when you downshift, you
could lose control of your vehicle. You could
injure yourself or others. Do not shift down
more than one gear at a time when you
downshift.
President: Susquehanna Valley GTO Inc.
president@svgto.com
Public Relations Coordinator: GTOAA
publicrelations@gtoaa.org
GTO JUDGE is online now
post #3 of 15 (permalink) Old 09-23-2008, 12:11 PM
AlaGreyGoat's Avatar
With a M6, 6500 RPM in 2nd is 69 MPH
Larry
2005 GTO Fast - 2004 Z06 Faster - 1984 Honda V65 Magna Fastest
AlaGreyGoat is offline
post #4 of 15 (permalink) Old 09-23-2008, 01:07 PM
Quoted: 20 Post(s)
Do you know that from experience?
post #5 of 15 (permalink) Old 09-23-2008, 01:10 PM
mr.gto's Avatar
it looks like there is a shift light stock on the dash right next to the 7k mark...... how do i get it to function?? cuz sometimes after leaving the burnout box i hit rev limiter by accident and it still doesnt come on or blink. And I have seen videos where this light works.
Feel the torque
mr.gto is offline
post #6 of 15 (permalink) Old 09-23-2008, 01:18 PM
Quoted: 11 Post(s)
That light is non functional however I hear there is a guy who can enable it for a fee. I was informed a new member of the forum ( )discovered a way to enable it. If what I heard is correct and they want to share their knowledge............ Many would be appreciated.
president@svgto.com
post #7 of 15 (permalink) Old 09-23-2008, 01:20 PM
here you go....
White Auto & Media - Instrument Cluster Programming
the only guy who can do it.
(I had done and it was worth it)
Ninjured is offline
post #8 of 15 (permalink) Old 09-23-2008, 01:20 PM
Quoted: 20 Post(s)
I could just ride shotgun and slap you in the back of the head when it's time to shift. j/k!
post #9 of 15 (permalink) Old 09-23-2008, 01:22 PM
Aramz06's Avatar
Send a message via AIM to Aramz06
Originally Posted by Ninjured View Post
here you go....
Need...
-LSS Shifter
-Resonator Delete
-Flowmaster 44 Series Mufflers
1 of 475
Aramz06 is offline
post #10 of 15 (permalink) Old 09-23-2008, 08:34 PM
fergyflyer's Avatar
Hence the term slap stick shifter!!!!!!
fergyflyer is offline
Human Verification
GTO Gear Ratio's geeteeohguy 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 149 06-13-2015 03:20 PM
Grinding noise when shifting from 1st to 2nd gear? O'Town Service, Maintenance and Technical Discussion 19 02-08-2008 05:07 PM
2nd gear issue, need advice imcordell Drive train, suspension, alignment and brakes. 8 04-09-2007 09:34 AM
2nd Gear Grind RipTheSix 2004-2006 GTO General Discussion 2 10-03-2006 10:15 AM
2nd gear skip GTO JUDGE 2004-2006 GTO General Discussion 3 06-04-2005 08:04 AM
