Hi all. I went to get into my car today and the key transmitter would not open the car/disengage the alarm. I tried over and over, then went in to get the spare key and got the same results. Eventually it worked and now seems fine. Very strange that it would be intermittent. A computer malfunction? Obviously it's not the key. Has anyone had similar problems with their keys?
Mine did the same thing along with my trunk not opening with the key. It was intermittently working on both key fobs. In my case it was the BCM (Body Control Module) that was on its way out.
Other's who have had problems have had their door actuator replaced.
The BCM is located up under the dash behind the glove box. If you need a new BCM you'll need your key codes. Your dealer can get them for you, but you can save time by having them ready.
IF it is your BCM, and it is replaced, make sure you get the NEW BCM key code. The old one will be outdated. All the other codes should remain the same. You will also get 2 new key fobs.
My key fob acts up from time to time as well. I'd hit the unlock button and get no response no matter how close I am to the car or how hard I'd press it. You can just open up the door w/ the key since the alarm will stop as soon as you start the car.
mine will respond in a similar matter if i have other keys near the key to unlock or lock. no matter how close or far. it's been like that from day one.
06 impulse blue/black/ m12 1 of 252
spoilerless with dba 4000 fronts. gone
78 chevy nova 2dr sbc 400/th350/8.5 (4 jackstand mod)
92 ford rustang lx notchback 5.0/t-5/8.8 LS still stock
FMS shorties, bbk x ,fms catback, air pump overrode.
