well apparently it was my tail lights causing the problem , i got those led lights put in and they were pulling too many ohms or something and i need a resisitor which i still have to figure out but if i have my stock lamps in there are no problems so if you have diff tail lights in that could be your problem!! gl
wow, that sounds crazzy! Wonder why would the TC use/monitor resistance through the tail light wires??
I had a similar problem w/ my traction control on the way to work today. It displayed the "trac off" indicator on the dash the whole time I was driving and wasn't able to turn it back on, the t/c button had no effect. Parked the car, went to work and when I started her up afterwards everything was fine. One time glitch or potential problem??
I'm having the same problem with my gto,
I just put in some led's and as soon as I step on the break the T/C goes off and my Tachometer doesn't seem to be accurate.
What kind of resister is there for it? Is there some type of balace I could use similar to HID lights?
Are there any other ideas of how to get it to work besides putting the stock lights back on. I like the led's much better.
i just got new tail lights that arent leds and they work fine i ddnt feel like dealing with the resistor or anything like that and all the bodyshops and other car shops had no clue what the hell i was talking about so i just said screw it and yes i checked all the fuses to the person that said could it be a blown fuse... good luck to all that keeps them!!
This may sound crazy but I had the same problem back a few months ago and
it was actually the MAF sensor causing it. It had caused the ABS to shut
down which in turn caused the traction control to remain off. Don't ask me
how. It was replaced under warranty, and I watched while they did all the trouble shooting. When they replaced the MAF sensor all was normal again. I had a thread on it at the time. I'll try to dig it up.
__________________ 1 of 370Black Metallic/Red/Manual/18"
80U 756 MN6 N87
I went to checkers auto and they had resistors in stock.
They had a whole section of LED lights.
I installed them to the tail lights and after a few adjustments my traction control is working again. I didn't have any problems with my cruise like others have mentioned.
If they are connected wrong your break lights will turn on with head lights.
My only problem now is when I have the key turned only to ignition and all the lights on the dash come on, when I turn it off the engine light stays on.
I take the key out and restart and it's back to normal.
The good thing I did was splice everything into the "light" side of the wires, so if I run into problems I can put the stock back in and take it to the dealer for warrenty work.
