P0300 Random Misfire issue - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 12-26-2012, 10:16 PM   #1 (permalink)
Hello everyone,
I have a LS1 GTO cat delete that is having some serious misfire issues. The check engine light flashes at 2000 to 4000 rpm, the light stays on at idle (rough idle) and no misfires over 4000 revolution. I check the wiring and nothing seems to be out of order and tried to detect which cylinder is misfiring but it's every one of the cylinder misfiring at random!
background: 04 LS1 GTO 62k miles. The car has headers, straight pipes, cat delete with diablosport O2off Tune. 3" Full exhaust with 2 32" resonators and mufflers.
I have recently started putting premium Costco gas in the car. My friend who gets gas from the same spot is having fuel related issues. He drives an integra GSR . Not sure if this is a coincidence or it is bad costco gas causing this.
I stopped by Autozone and put a whole thing of fuel injector cleaner and octane boost with hydration eliminator in the car and drove it home for 10 miles. It didn't drive any better!
The car sounds and drives like a tractor and I dont wanna damage anything so you help is definitely appreciated.
Alireza is offline   Reply With Quote
Old 12-31-2012, 09:43 PM   #2 (permalink)
B-ville Goat's Avatar
Pull the plugs and check them. Also try filling at a different station to see if that helps?
Vice President
Susquehanna Valley GTOs
B-ville Goat is online now   Reply With Quote
Old 01-01-2013, 08:44 AM   #3 (permalink)
HP11's Avatar
My Photos: (20)
A good reason not to use fuel additives. You'll probably need to burn those additives out of your fuel system and then run a tank or two of gas from the 'different station' before you could rule out the gas itself being the problem.
2005 Pontaic GTO -CGM 6 Speed
1983 Chevrolet El Camino Conquista
1997 Acura 3.2TL Premium (Extra car)
Certified HVAC/MVAC Technician
HP11 is online now   Reply With Quote
Old 01-03-2013, 08:15 AM   #4 (permalink)
My Photos: (1)
Make sure there is no clog in airflow either, recently seen issues of MAF or just clogs causing not enough air and misfirings happen bad at idle but as the vehicle was higher rev was fine.
Jeffcarr is offline   Reply With Quote
P0300 code taz4141 2004-2006 GTO General Discussion 6 05-11-2012 10:12 PM
Misfire at idle really bugging me Gtojustin Service, Maintenance and Technical Discussion 4 04-04-2012 08:51 PM
random misfire trouble code ? help Bossin Service, Maintenance and Technical Discussion 10 09-25-2011 05:53 PM
06 gto misfire s10ss Service, Maintenance and Technical Discussion 9 01-04-2011 08:48 PM
Gto Misfire KennedyKustoms Engine Discussions 6 04-21-2010 12:11 AM
SEO by vBSEO 3.3.2
