rear output shaft seal - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-19-2017, 06:12 PM Thread Starter
I have a stock 06 gto Manual transmission. I blew the rear output shaft seal. I damaged the metal shield that goes around the driveshaft and inside the seal. It has a few bumps. Anyone know how to fix this?
Kyle S is offline
post #2 of 2 (permalink) Old 05-19-2017, 07:16 PM
GTO44's Avatar
Quoted: 27 Post(s)
So what you are calling the "metal shield" is the tailshaft bushing. I'm actually dealing with the same thing. My 1 piece driveshaft vibrating at high speed ate up my bushing and wore out the seal. Trans is now leaking out of the tailshaft.
You can pop the output shaft seal out with a flat head screw driver once the driveshaft it out. Trying to press it back in is tricky but you can do it without the need for specialized tools. The metal bushing is harder as you need output shaft bushing tool or the formal name "Universal transmission extension housing bushing tool".
Here's a link to the tool: (*edit* this is an example of the tool... not the one for our specific t-56)
Save on ATEC Trans Tool T-0160-A at USA Tool Warehouse Automotive Tools
This will allow you to pull the bushing and get it back in properly.
What I'm doing is removing the tailshaft and bringing it to a transmission shop to replace the metal bushing and the seal. They did say it would be around $100 to bring the car in and have them do everything. But I have to put another driveshaft in it anyways and tighten the shifter bolts on my MGW-P, so it's not too much harder at that point for me to pull the tailshaft out. For your situation it may be easier just to drive it to a trans shop and have them fix it.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
Human Verification
Output shaft excessive play I T8 I Service, Maintenance and Technical Discussion 8 12-03-2016 07:02 AM
Transmision Output shaft Caribbean Goat Drive train, suspension, alignment and brakes. 0 02-02-2016 07:50 PM
68 GTO Steering Shaft output m.e.g. 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 04-16-2012 11:09 PM
M20 output shaft upgrade? IGOTGOAT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-29-2010 06:48 PM
Rear seal replace gman26 1964-1974 Tempest, Lemans & GTO General Discussion 3 01-22-2006 12:30 AM
