1. Are there any special tools necessary to change the tranny or differential oils? Nope. Backup switch requires a 7/8" wrench, drain plug's a 3/8" drive hole and the diff's a 30mm. Getting oil through the backup switch requires either a fluid pump or the running of a hose down through the engine bay.
2. Where is the backup switch located? Driver's side. Mid-transmission, half way up.
3. I have been an Amzoil user and occassionaly a dealer for 30 years, I am planning on using Amziol Torque Drive rather than regular ATF because of the power of the LS2. Anyone else have thoughts? Dexron III's in there now, so replace with Dexron III or Dexron VI. The amount required is 4.6 quarts. Wouldn't worry about the brand so much as it meeting the Dexron spec.
