Old 04-16-2008, 07:10 PM   #1 (permalink)
bassist3453's Avatar
Send a message via AIM to bassist3453
Weird rattling/chatter '04 6MT
It makes a weird noise that sounds like its coming from maybe the flywheel/clutch area but I'm not sure because it does it when I'm driving. Sometimes it is at idle, but mostly under acceleration, especially at low revs in a higher gear. Slightly concerned since I just got it three weeks ago. Confession, I first noticed it after I forgot I was in gear and dumped out the clutch with the brakes on after I had just started it in a parking lot. First stick shift so I didn't think about those things for a while. Any ideas? Also, my rear end sounds a little clunky between shifts, is that common on these cars?
bassist3453 is offline   Reply With Quote
Old 04-16-2008, 07:15 PM   #2 (permalink)
My Photos: (46)
None of the problems you list is normal.. Check this link...
Growling/Clunking Noise Coming from the Rear
As far as the flywheel/clutch area, take it in for a check-up.
Vice President : SVGTO Tigers
Member
Old 04-16-2008, 09:38 PM   #3 (permalink)
thanks. i'm taking it into carmax (where i got it from) tomorrow. its still under their 30 day warranty so if somethin is wrong with then they will fix it on their tab.
Old 04-22-2008, 06:20 PM   #4 (permalink)
2006GTOLS2's Avatar
Well, hopefully they will consult the dealership about this problem, and refer it to them. I'm sure they don't have a clue about what the problem might be, or how to work on a GTO.
2006 Spice Red M6 - StolenFox Flowmaster Super 44 Axlebacks, StolenFox H-Pipe, U7191 Predator Rev. 9r01 - Custom tuned
2005 Torrid Red M6 - Sold
2001 Chevrolet S10 LS, Pewter Metallic, Ext. Cab, 4.3L, 4L60E, 3.42
2006GTOLS2 is offline   Reply With Quote
Old 04-28-2008, 08:25 PM   #5 (permalink)
fixed
they fixed it. it was just an exhaust hanger that had come loose, but i still cant wrap my head around why it was just at start up. weird. shifts can still sound clunky, but its not a big issue.
Old 04-29-2008, 06:46 AM   #6 (permalink)
My Photos: (46)
Well that's good, at least was a simple fix.
The "clunky" will become a big issue if you don't address it. IF it is the rear end which you describe it may be, the viscosity of oil is breaking down and eventually heat build up on the gears will take it's toll and you may have some $$ issues after warranty. IMO, I'd take it to be looked at and get the oil changed out. It's a warranty claim.
Even if it's not what I describe, you'll know what it is after it's inspected.
Member
Old 04-29-2008, 07:21 AM   #7 (permalink)
Moderator
My Photos: (16)
Regular rear end lube goes for 100s of thousands of miles in other cars/trucks, why is the GTO an issue for the synthetic lube wearing out so quick??
Old 04-29-2008, 07:34 AM   #8 (permalink)
My Photos: (46)
I don't know. The oil in mine broke down in only 17K miles if I remember correctly.
Maybe Dana failed to add the Friction Modifier, or the FM was found it quieted the rears down after complaints? I do know Dana will use the least expensive oils they can unless the customer specifies a particular oil. Dana had a bunch of bad rear ends built (the whine issue). The first step in trying to correct the whine was to replace the oil with synthetics with the FM.
I am suspecting when Dana built the "good ones" after the warranty replacements began, they didn't change the oil used. (my opinion).
One day all the sudden after roughly 17K miles on the new rear the clunking began. The FM is liquid gold.
Member
Old 04-29-2008, 11:04 AM   #9 (permalink)
ill look into it. if thats the problem it wont be a big deal to get the gear oil changed. better than buying new gears or worse down the road.
My new 67 - a weird combination?? 428GOAT 1964-1974 GTO General Discussion 18 02-09-2008 05:08 PM
06 acting weird muscleT 2004-2006 GTO General Discussion 3 01-04-2008 06:13 AM
2006 Silver GTO 6MT bchguy111 2004-2006 GTOs for Sale 3 09-02-2007 04:27 AM
Weird - Temp Spike Anomaly Groucho Service, Maintenance and Technical Discussion 9 05-20-2005 09:27 AM
6MT vs. Auto (track times) D_Nyholm 2004-2006 GTO General Discussion 4 03-31-2005 10:31 AM
