I heard it isnt a bad idea to change the factory plugs on the ls2. I was thinking the NGK V-Power Spark Plug; TR55; @ Gap .060? is that the correct gap or should i change?
Thanks Dennis
I wouldn’t consider it a bad thing to do. Matter of fact, I’m going to pick up some myself. As far as the gap, I’ve seen some at .50 and .55. I’m in no way an expert on spark plugs, but from what I’ve read, TR 55’s are for mostly stock cars with heavily modded cars using TR6’s. Hopefully somebody else could shed a little more light on this topic.
I was just lookin at partsamerica.com and looked up the ls2 and thats the only tr55 they sell are 60..the rest of the plugs they sell are all .40... but im not expert either so im not sure what to buy.
The gap that plugs come in doesn't matter. That can be changed with a gap tool. Its a little piece of metal that has both sides angled, one usually from .020-.045, and the other side from .045-.070. Just slide the tool between the curved metal and the base post up to whatever gap you want. Most tools also have a hook on it to bend the gap back. Basically all you are looking for is a plug that is slightly hotter or colder than stock, depending on what you wanna do. On my 69 GTO, with GM HEI ignition, I used the R44s with a gap of .047 , but the stock plug was R45s w/ gap of .035, Ram Air IV used a R44s w/ gap of .035. It all depends on what your specific engine likes. Just buy the tool, and try a bunch of different gaps.
A quick guide:
Bigger gaps= more spark travel (better combustion burn), but can get covered in gunk easier
Smaller gaps= less spark travel(worse burn), and less chance of gunk
Started with T55's when the cam went in and changed to the Tr6's. not a bad idea to change them.
I bought 8 new t55s and a tool to change the gap. Hoping to do on wensday
You'll be surprised how much power the right plugs and gaps will give you. On my 69, I gained 9 hp and 5 torqe. And those are just AC delco plugs. A nice cheap way to get a little power. Good luck, it is worth the time to get em right.
Thanks for the info. I might just replace them to make sure they are right and to inspect the factory intalled ones for anything abnormal. Besides, this is the first new car I've purchased in the last 15 years or so where I can actually get to the plugs.
Can I put tr66 even though I aint got a maggie yet? I'm gona get a cam first than a maggie next summer! I got a volant CAI,SLP lt, 3inch custom muffs, getting the tune done at cam change!
