Hi Guys
New here to the forum,just purchased a 1974 red gto with 36k original,has 4 sp and air,white bench style seat,pictures soon,,can't move car as this part is not working properly,plastic with a two prong connector and a slide mech that slides in when you push the clutch in to start the car,took it off from clutch pedal,need a new one but dont. know what it is called,,any help,,thanks
Charles
Welcome to the forums.
I believe that's called a clutch safety switch. Crossing the two wires that connects there and you would be by-passing the switch and the car starter should work with the key again until you can get a replacement switch.
thanks guys
that's what I needed,,will get pictures of the car up soon ,,
Charles
Does anyone know where to purchase one of these parts??
Let me know,,,
and last but not least,,the person I'm getting the gto from has many engines and heads for sale, lots of ram air stuff, also tri power setups ,saw a ra4 or 5 sr block with dealer tag on it and about 6 other more rare gto engines from 67 ,68 ,69 ,the stuffs not cheap but if you need something I could ask them,,they have 4 other gtos for sale,one I remember is a 67 400 ho car with air and 4 speed ,I will need part numbers or dates to look for certain items,,no promises they have what you need but I could check,,
Charles
Reason: lots more info
as promised,,got the car home,mostly original paint,under 40k,its a three speed not a four,underside stripped and por coated,engine rebuilt,engine bay detailed,interior no rips or holes in seats needs dash pad and carpet only,hope to have it painted by spring,,
Charles,
