Air Conditioner Causes Squeling/Chirping - Pontiac GTO Forum
post #1 of 9 (permalink) Old 07-12-2010, 04:20 PM Thread Starter
BlackJackByte's Avatar
Any clues to what this might be guys? Only makes the noise when I turn the AC on, and if I go into neutral it seems to stop. Very annoying and kinda loud-ish.
2004 M6 Yellow Jacket.
BlackJackByte is offline
post #2 of 9 (permalink) Old 07-12-2010, 04:26 PM
jpalamar's Avatar
Your AC might need recharged(I believe the stuff it is filled with has an oil in it). Also, is your compressor cluch working?
jpalamar is offline
post #3 of 9 (permalink) Old 07-12-2010, 04:47 PM
HP11's Avatar
Quoted: 11 Post(s)
Squeling in not a sign of a low charge condition. Check your belt tensioner. There are two. I'm talking about the lower one on that tensions the compressor belt.
2004 Ford Ranger Edge Supercab (My daily driver)
HP11 is online now
post #4 of 9 (permalink) Old 07-13-2010, 12:14 AM
jetstang's Avatar
It might be a bad idler pulley on the AC, not applying enough tension to the belt. Or the AC is overcharged causing excessive drag on the compressor causing belt slippage. May just be time for a new AC belt.
Burning rubber since 1982!!
jetstang is offline
post #5 of 9 (permalink) Old 07-13-2010, 08:56 AM
Quoted: 20 Post(s)
Belt might need to be replaced.
post #6 of 9 (permalink) Old 07-13-2010, 09:32 AM
HP11's Avatar
Quoted: 11 Post(s)
Yeah, let's rule out overcharge/undercharge as earlier suggested. He never that said it wasn't getting cold. For it to be overcharged, someone would have has to have overcharged it (again not mentioned). The info given leads me to either the belt tensioner (idler pulley) as I suggested or the belt itself.
HP11 is online now
post #7 of 9 (permalink) Old 07-13-2010, 10:56 AM Thread Starter
Guys, thanks a ton. I'll check when I get home. My AC is VERY COLD by the way. I havent done anything to the AC since ownership about a year ago. As always thanks for the big help, thats what I love about this forum.
post #8 of 9 (permalink) Old 07-30-2010, 06:36 PM
VenomGTO's Avatar
probably just a belt, not enough tension. what part of indiana u from? im in evansville...
2005 Impulse Blue GTO, blue leather interior, 6speed.
VenomGTO is offline
post #9 of 9 (permalink) Old 09-04-2010, 12:13 AM
im having a similar problem but mine is constant. it started slowly. first only when i accelerated, now its squiring even during idle. i had the ac recharged recently, but i highly doubt thats it.
CreditDept is offline
  Pontiac GTO Forum > The 2004-2006 GTO > Engine Discussions
Human Verification
Air Conditioner? SueY816 2004-2006 GTO General Discussion 20 06-07-2010 01:30 PM
Chirping Noise When Turning Left?! kdkiernan Drive train, suspension, alignment and brakes. 16 10-16-2009 07:51 PM
Chirping Sound While Driving Michael.Narlock Service, Maintenance and Technical Discussion 8 02-01-2009 01:05 AM
Rear chirping sounds when hitting bumps PatrickNJ Drive train, suspension, alignment and brakes. 10 09-03-2008 11:16 AM
1971 - 72 GTO Ram Air air filter slickman 1964-1974 Tempest, Lemans & GTO General Discussion 1 10-19-2006 09:44 PM
