Electric Supercharger? - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 11-13-2012, 07:51 PM   #1 (permalink)
I know when first hearing of these a long time ago I completely dismissed the idea of it being capable of providing any gains. However, is it possible for one of these electric superchargers to provide the boost they claim? I'm seeing claims between 3 to 5 PSI using one of these. On our 5.7 or 6.0 motors that could result in a decent power increase. I'm figuring however our engines take in so much air that the flow required would render any compression? I could also see reliability issues in an electric version of a supercharger. That an amperage draw is between 5 to 10 amps. Can that be supported by the alternator? Please comment with reliable information. Don't just say it can't work because that's how you feel about the product. Thanks.
GTE 5PSI Max Vortex Electric supercharger Air Induction Kit | eBay
Electric supercharger Eturbo Patented and Proven Design DIY EV HP Gains Custom | eBay
gt4awd is offline   Reply With Quote
Old 11-13-2012, 07:57 PM   #2 (permalink)
HP11's Avatar
My Photos: (20)
To borrow a term from my grand daughter: Seriously???
READ: http://www.wildweasel.ca/HowTo/Auto/eturbo.aspx
2005 Pontaic GTO -CGM 6 Speed
1983 Chevrolet El Camino Conquista
1997 Acura 3.2TL Premium (Extra car)
Certified HVAC/MVAC Technician
HP11 is online now   Reply With Quote
Old 11-13-2012, 08:11 PM   #3 (permalink)
Good read. That's what I figured. These electric fans spin at most 20k RPM. A turbo or supercharger reaches much higher RPM. Thanks, LOL...
Old 11-14-2012, 05:03 AM   #4 (permalink)
porkandbeans's Avatar
Yeah . . . good luck with that.
I was thinking of a bunch of responses. HP11 summed it up perfectly with that article. Thanks HP11!
porkandbeans is offline   Reply With Quote
Old 11-14-2012, 07:35 AM   #5 (permalink)
ahh why go electric go gas
sam5828 is offline   Reply With Quote
Old 11-14-2012, 11:09 AM   #6 (permalink)
HP11's Avatar
My Photos: (20)
Got to love the moron(s) standing in front of a vehicle during a dyno pull......
Old 11-14-2012, 06:48 PM   #7 (permalink)
jetstang's Avatar
My Photos: (10)
Leaf blower produces more CFM than a little electric motor. A BIG electric motor will def build boost. My killer idea back in the day was to put a air tank on the front and dispense it for boost, no loss on the motor. I went to Gartlits Museum in Ocala and they had a dragster with a big tank in the middle, already done. The reality is, if your going to install a tank, you might as well fill it with Nitrous.. Turbos and superchargers are RPM dependent on level of boost progressivelly, not all at once like a electric motor.
Burning rubber since 1982!!
jetstang is offline   Reply With Quote
Old 11-14-2012, 08:21 PM   #8 (permalink)
FlambeauHO's Avatar
My Photos: (5)
Loading your alternator with that kind of current draw is robbing plenty of power on its own.
FlambeauHO is online now   Reply With Quote
Old 11-16-2012, 01:31 AM   #9 (permalink)
Papa Rad's Avatar
Those things are ebay pos's. I got a cheap $20 for my alero back in the day, It actually made things worse.
Difflow diffuser, K&N intake, x pipe only exhaust, HO alternator, pioneer touch screen, 55w HID's, 35w fogs, halo/projector headlights, fender stripe, 5%-15% window tint, black lug nut caps, black side markers, more to come
Papa Rad is offline   Reply With Quote
Old 11-16-2012, 06:04 AM   #10 (permalink)
AlaGreyGoat's Avatar
A 400ci motor requires 694 cfm @ 6000 rpm @ atmospheric pressure @ 100% efficiency.
A normal motor runs about 85 to 95% efficiency and at a low vacuum. To produce a boost
in intake pressure would require considerably more cfm. At 14.7 psi boost would require
2 times the flow, 1388 cfm. No small electric fan can come close.
A 24" Dia x 60" long air tank holds 15.7 cu ft @ atmospheric pressure and 160 cu ft @ 150 psi,
It could provide some boost for a few seconds, but would require special plumbing, ie, large valves,
regulators, and hosing and special valving to keep the boost for going out the intake input on
boost and allow normal intake other times.
Larry
2005 GTO Fast - 2004 Z06 Faster - 1984 Honda V65 Magna Fastest
AlaGreyGoat is online now   Reply With Quote
new, GTO still no start, electric? yousaygo 1964-1974 Tempest, LeMans & GTO Technical Discussions 29 07-23-2011 08:23 PM
electric turbo Bluegoat05 Engine Discussions 28 05-01-2010 10:36 PM
67 GTO Electric journeymate Member Introductions 1 01-22-2009 09:42 PM
69 gto electric fan question 1969gtojohn 1964-1974 GTO General Discussion 1 05-01-2008 02:51 PM
SEO by vBSEO 3.3.2
