Pontiac GTO Pontiac GTO Forum
» Sponsors
» Sponsors
Register Home Forum Active Topics Photo Gallery Search Today's Posts Mark Forums Read
GtoForum.com is the premier Pontiac GTO forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Closed Thread
Old 02-19-2007, 07:09 AM   #1 (permalink)
I need help with a 1969 400 Engine!
I am new to Pontiacs and am attempting to install a points dist in my 1969 Pontiac 400 in place of an HEI that had been installed. I brought engine around to #1 tdc (balancer line at 0) and wired firing order from there. I have not been able to get the car to run as it appears firing order is off even though I have triple checked everything.
My continued problems make no sense...so I double check the shop manual and the procedure for setting the dist IF dist removed and engine turned over...pull plug #1, crank engine until compression felt and bring the crank around to position in picture # whatever...but picture # whatever shows the balancer mark lined up with first mark on timing tab...12 degree btdc...it is crystal clear that balancer is NOT brought around to 0 mark on timing tab. That is contrary to every engine I ever worked on...Is this a Pontiac thing? Are there any engine builders who know? Please email me at caminosrule@aol.com. Thanks.
GM
gpm6367 is offline
Old 02-19-2007, 01:22 PM   #2 (permalink)
My Photos: (471)
Refer to this thread with answers;
http://www.gtoforum.com/showthread.p...311#post108311
05GTO is online now
Closed Thread
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
