LS2 engine specifications - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-01-2010, 11:20 AM Thread Starter
Pulled from:
LS2 engine specs! - Aussie V8 | Holden - Ford | Australian V8 Engine Community
Engine Type
V8
Displacement
6.0L
364 CID
RPO
LS2
VIN
U
Bore
101.618-101.636 mm
4.0007-4.0017 in
Stroke
92.0 mm
3.622 in
Compression Ratio
10.9:1
Firing Order
1-8-7-2-6-5-4-3
Spark Plug Gap
1.02 mm
0.04 in
Block
Camshaft Bearing Bore 1 and 5 Diameter
59.58-59.63 mm
2.345-2.347 in
Camshaft Bearing Bore 2 and 4 Diameter
59.08-59.13 mm
2.325-2.327 in
Camshaft Bearing Bore 3 Diameter
58.58-58.63 mm
2.306-2.308 in
Crankshaft Main Bearing Bore Diameter
69.871-69.889 mm
2.75-2.751 in
Crankshaft Main Bearing Bore Out-of-Round
0.006 mm
0.0002 in
Cylinder Bore Diameter
101.618-101.636 mm
4.0007-4.0017 in
Cylinder Bore Taper - Thrust Side
0.018 mm
0.0007 in
Cylinder Head Deck Height - Measuring from the Centerline of Crankshaft to the Deck Face
234.57-234.82 mm
9.235-9.245 in
Cylinder Head Deck Surface Flatness - Measured Within a 152.4 mm (6.0 in) Area
0.11 mm
0.004 in
Cylinder Head Deck Surface Flatness - Measuring the Overall Length of the Block Deck
0.22 mm
0.008 in
Valve Lifter Bore Diameter
21.417-21.443 mm
0.843-0.844 in
Camshaft
Camshaft End Play
0.025-0.305 mm
0.001-0.012 in
Camshaft Journal Diameter
54.99-55.04 mm
2.164-2.166 in
Camshaft Journal Out-of-Round
0.025 mm
0.001 in
Camshaft Lobe Lift - Intake
7.78 mm
0.306 in
Camshaft Lobe Lift - Exhaust
7.77 mm
0.305 in
Camshaft Runout - Measured at the Intermediate Journals
0.05 mm
0.002 in
Connecting Rod
Connecting Rod Bearing Clearance - Production
0.023-0.065 mm
0.0009-0.0025 in
Connecting Rod Bearing Clearance - Service
0.023-0.076 mm
0.0009-0.003 in
Connecting Rod Bore Diameter - Bearing End
56.505-56.525 mm
2.224-2.225 in
Connecting Rod Bore Out-of-Round - Bearing End - Production
0.004-0.008 mm
0.00015-0.0003 in
Connecting Rod Bore Out-of-Round - Bearing End - Service
0.004-0.008 mm
0.00015-0.0003 in
Connecting Rod Side Clearance
0.11-0.51 mm
0.00433-0.02 in
Crankshaft
Connecting Rod Journal Diameter - Production
53.318-53.338 mm
2.0991-2.0999 in
Connecting Rod Journal Diameter - Service
53.308 mm
2.0987 in
Connecting Rod Journal Out-of-Round - Production
0.005 mm
0.0002 in
Connecting Rod Journal Out-of-Round - Service
0.01 mm
0.0004 in
Connecting Rod Journal Taper - Maximum for 1/2 of Journal Length - Production
0.005 mm
0.0002 in
Connecting Rod Journal Taper - Maximum for 1/2 of Journal Length - Service
0.02 mm
0.00078 in
Crankshaft End Play
0.04-0.2 mm
0.0015-0.0078 in
Crankshaft Main Bearing Clearance - Production
0.02-0.052 mm
0.0008-0.0021 in
Crankshaft Main Bearing Clearance - Service
0.02-0.065 mm
0.0008-0.0025 in
Crankshaft Main Journal Diameter - Production
64.992-65.008 mm
2.558-2.559 in
Crankshaft Main Journal Diameter - Service
64.992 mm
2.558 in
Crankshaft Main Journal Out-of-Round - Production
0.003 mm
0.000118 in
Crankshaft Main Journal Out-of-Round - Service
0.008 mm
0.0003 in
Crankshaft Main Journal Taper - Production
0.01 mm
0.0004 in
Crankshaft Main Journal Taper - Service
0.02 mm
0.00078 in
Crankshaft Rear Flange Runout
0.05 mm
0.002 in
Crankshaft Reluctor Ring Runout - Measured 1.0 mm (0.04 in) Below Tooth Diameter
0.7 mm
0.028 in
Crankshaft Thrust Surface - Production
26.14-26.22 mm
1.029-1.0315 in
Crankshaft Thrust Surface - Service
26.22 mm
1.0315 in
Crankshaft Thrust Surface Runout
0.025 mm
0.001 in
Cylinder Head
Cylinder Head Height/Thickness - Measured from the Cylinder Head Deck to the Valve Rocker Arm Cover Seal Surface
120.2 mm
4.732 in
Surface Flatness - Block Deck - Measured Within a 152.4 mm (6.0 in) Area
0.08 mm
0.003 in
Surface Flatness - Block Deck - Measuring the Overall Length of the Cylinder Head
0.1 mm
0.004 in
Surface Flatness - Exhaust Manifold Deck
0.13 mm
0.005 in
Surface Flatness - Intake Manifold Deck
0.08 mm
0.0031 in
Valve Guide Installed Height - Measured from the Spring Seat Surface to the Top of the Guide
17.32 mm
0.682 in
Intake Manifold
Surface Flatness - Measured at Gasket Sealing Surfaces and Measured Within a 200 mm (7.87 in) Area that Includes Two Runner Port Openings
0.3 mm
0.118 in
Lubrication System
Oil Capacity - with Filter
5.2 liters
5.5 quarts
Oil Capacity - without Filter
4.7 liters
5.0 quarts
Oil Pressure - Minimum - Hot
41 kPa at 1,000 engine RPM
124 kPa at 2,000 engine RPM
165 kPa at 4,000 engine RPM
6 psig at 1,000 engine RPM
18 psig at 2,000 engine RPM
24 psig at 4,000 engine RPM
Oil Pan
Front Cover Alignment - at Oil Pan Surface
0.0-0.5 mm
0.0-0.02 in
Rear Cover Alignment - at Oil Pan Surface
0.0-0.5 mm
0.0-0.02 in
Oil Pan Alignment - to Rear of Engine Block at Transmission Bell Housing Mounting Surface
0.0-0.25 mm
0.0-0.01 in
Piston Rings
Piston Ring End Gap - First Compression Ring - Measured in Cylinder Bore - Production
0.20-0.41 mm
0.008-0.016 in
Piston Ring End Gap - First Compression Ring - Measured in Cylinder Bore - Service
0.20-0.41 mm
0.008-0.016 in
Piston Ring End Gap - Second Compression Ring - Measured in Cylinder Bore - Production
0.37-0.69 mm
0.015-0.027 in
Piston Ring End Gap - Second Compression Ring - Measured in Cylinder Bore - Service
0.37-0.69 mm
0.015-0.027 in
Piston Ring End Gap - Oil Control Ring - Measured in Cylinder Bore - Production
0.22-0.79 mm
0.009-0.031 in
Piston Ring End Gap - Oil Control Ring - Measured in Cylinder Bore - Service
0.22-0.79 mm
0.009-0.031 in
Piston Ring to Groove Clearance - First Compression Ring - Production
0.030-0.10 mm
0.0012-0.0040 in
Piston Ring to Groove Clearance - First Compression Ring - Service
0.030-0.10 mm
0.0012-0.0040 in
Piston Ring to Groove Clearance - Second Compression Ring - Production
0.035-0.078 mm
0.0014-0.0031 in
Piston Ring to Groove Clearance - Second Compression Ring - Service
0.035-0.0078 mm
0.0014-0.0031 in
Piston Ring to Groove Clearance - Oil Control Ring - Production
0.013-0.201 mm
0.0005-0.0079 in
Piston Ring to Groove Clearance - Oil Control Ring - Service
0.013-0.201 mm
0.0005-0.0079 in
Pistons and Pins
Pin - Piston Pin Clearance to Piston Pin Bore - Production
0.002-0.01 mm
0.00008-0.0004 in
Pin - Piston Pin Clearance to Piston Pin Bore - Service
0.002-0.015 mm
0.00008-0.0006 in
Pin - Piston Pin Diameter
23.952-23.955 mm
0.943-0.943 in
Pin - Piston Pin Fit in Connecting Rod Bore - Production
0.007-0.02 mm
0.00027-0.00078 in
Pin - Piston Pin Fit in Connecting Rod Bore - Service
0.007-0.022 mm
0.00027-0.00086 in
Piston - Piston Diameter - Measured Over Skirt Coating
0.00-0.00 mm
0.00-0.00 in
Piston - Piston to Bore Clearance - Production
0.00-0.00 mm
0.00-0.00 in
Piston - Piston to Bore Clearance - Service Limit with Skirt Coating Worn Off
0.00-0.00 mm
0.00-0.00 in
Valve System
Valves - Valve Face Angle
45 degrees
Valves - Valve Face Width
1.25 mm
0.05 in
Valves - Valve Lash
Net Lash - No Adjustment
Valves - Valve Lift - Intake
13.27 mm
0.522 in
Valves - Valve Lift - Exhaust
13.25 mm
0.521 in
Valves - Valve Seat Angle
46 degrees
Valves - Valve Seat Runout
0.05 mm
0.002 in
Valves - Valve Seat Width - Exhaust
1.78 mm
0.07 in
Valves - Seat Width - Intake
1.02 mm
0.04 in
Valves - Valve Stem Diameter - Production
7.955-7.976 mm
0.313-0.314 in
Valves - Valve Stem Diameter - Service
7.95 mm
0.313 in
Valves - Valve Stem-to-Guide Clearance - Production - Intake
0.025-0.066 mm
0.001-0.0026 in
Valves - Valve Stem-to-Guide Clearance - Service - Intake
0.093 mm
0.0037 in
Valves - Valve Stem-to-Guide Clearance - Production - Exhaust
0.025-0.066 mm
0.001-0.0026 in
Valves - Valve Stem-to-Guide Clearance - Service - Exhaust
0.093 mm
0.0037 in
Rocker Arms - Valve Rocker Arm Ratio
1.70:1
Valve Springs - Valve Spring Free Length
52.9 mm
2.08 in
Valve Springs - Valve Spring Installed Height
45.75 mm
1.8 in
Valve Springs - Valve Spring Load - Closed
340 N at 45.75 mm
76 lb at 1.8 in
Valve Springs - Valve Spring Load - Open
980 N at 33.55 mm
220 lb at 1.32 in
My Youtube Channel
Supercharged (Roots) 6.0 GTO
Supercharged (Twin Screw) 3.0 NSX
Supercharged (Centrifugal) 4.3 S-10
batmans is offline
  Pontiac GTO Forum > The 2004-2006 GTO > Engine Discussions
Human Verification
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
LS1 or LS2 ENGINE DRESS UP 2004goat 2004-2006 GTO General Discussion 8 02-21-2010 06:42 PM
Ls2 Engine Covers cody6.0 General Classifieds 1 01-30-2008 05:14 PM
WTB: LS2 Engine Harness pick_a_part 2004-2006 GTO Parts for Sale (Price & Pictures Required) 0 04-04-2007 10:35 AM
LS2 Engine Codes and Deciphering it... patisi 2004-2006 GTO General Discussion 0 02-26-2006 03:46 PM
LS2 Engine noise joegoat Service, Maintenance and Technical Discussion 3 04-27-2005 07:35 PM
