I was on the GMPP website yesterday and was looking at replacing my LS2, with an LS3. The reason is to keep the miles off the LS2. I was wondering if anyone here has heard of anyone swapping an LS3 into a GTO yet. I asked the GMPP people what kind of problems i would run into by doing the swap. They said no one they know of has done it yet, but the accessories should be able to be transfered to the LS3 and should mount into stock motor mount locations. The only question they had was the computer controlling the engine. Does anyone have any other info? Thanks!!
Why do you want to keep the miles off of your LS2. To me makes NO sense, especially if you have the cash to plop in an LS3 (only 50 more hp, which you can buy for a lot less)
I would like to keep the car for a while, and hope that it increases in value. Removing the stock motor with only 7500miles on it is only going to help the value in 20 years. I know it sounds crazy, but every part i have taken off the car is stored right now, including all nuts and bolts so i can return it back to stock. Believe me this is not a definite purchase, just an idea and i respect your question.
i know buying another LS2 is an option in the future, but having unrestored original drive train components in perfect condition will really help the value. I'm sure many other things will need replacing in 20-25 years, and i think that having the major stuff, like motor/trans taken car of would be nice. Back to the original question, does anyone know of LS3 transplants, and any problems that might arise. I was just reading my motor trend and they have the Commadore with the LS7 dropped in, and it bolted right to the stock motor mounts and transmission. They just had to do a couple things like a custom dry sump oil system.
Though I still don't understand your thinking. If you want more power it will be so much easier to do bolt ons and a cam swap. Even with the LS3 you will STILL be putting miles on the car. Unless you just let it sit then it's pretty much pointless to try to keep it in mint shape and worth a lot of money.
Who's to say that the GTO is going to be worth anything in 20, 30 or even 40 years? Don't waste your time and money. Enjoy your car. With all the money it's going to cost you to swap in new drivetrain components you're probably better off parking your current goat and buying another one as a I-don't-really-care-about-the-mileage ride that you can drive as much as you want.
And let's face the truth here. It's not just low mileage on the drivetrain that makes a car valuable. Minimum wear and tear on the entire car is the key. What you're thinking of doing may cost you thousands of dollars as opposed to just parking the car and letting it sit. Who knows?
for the cost and the headache i would just swap in an aftermarket engine instead of a factory engine. to answer your question yes an ls3 will fit. any lsx engine will fit with little to no modification. you will have to reconfigure your ecm for the new displacement and i would keep the DBW system just to keep things simple. ls7 since it is a dry sump system would require the most. that and maybe the ls4 found in the monte ss and impala ss since it is a fwd application
06 impulse blue/black/ m12 1 of 252
spoilerless with dba 4000 fronts. gone
78 chevy nova 2dr sbc 400/th350/8.5 (4 jackstand mod)
92 ford rustang lx notchback 5.0/t-5/8.8 LS still stock
FMS shorties, bbk x ,fms catback, air pump overrode.
