Old 08-02-2008, 09:47 PM   #1 (permalink)
Need Help With Engine Tick
I have an 05 GTO I bought used. I had a CarFax report run and everything came back clean. I have an engine tick coming from the middle/right side (looking at the engine). You only hear it while idling. I thought maybe it was a valve problem so I took it into the shop. They ran some tests and took a computer graph of the motor. They said to come back in 1500 miles to see if it has gotten worse. I plan on taking it back in this week but so far I think it has gotten a bit worse. They at first thought it was a valve spring sticking but then said it could be the natural motor sound. I also pointed out to them that they car has a rough idle which I thought had something to do with the ticking. Does the car naturally have a mild shake while idling? Does anyone know what the ticking could be?
msauce18 is offline   Reply With Quote
Old 08-03-2008, 07:57 AM   #2 (permalink)
My Photos: (451)
I had the same ticking, the dealer changed one of the belt tensioners and fixed the problem. You can test by removing one belt at a time and running for a short time.
Old 08-03-2008, 09:01 AM   #3 (permalink)
raspantienator's Avatar
Good advice.
I have a slight one I hear only when in the garage but it's too slight to do anything.
I will try the belt thing first though when the time occurs.
raspantienator is offline   Reply With Quote
Old 08-04-2008, 08:56 PM   #4 (permalink)
mine has a slight shake- it seems more pronounced after my exhaust install. My old car used to tick and it was nothing abnormal- it would do it until it warmed up.
I just found a vein and started my addiction with:
kooks headers, catless mids, LPE intake, 160 thermo, IAT relocate, and a shifter that doesn't lick sweaty donkey balls- waiting on delivery!
v8newb is offline   Reply With Quote
Old 08-05-2008, 07:57 AM   #5 (permalink)
My Photos: (46)
The slight shake you are experiencing is cam lope. It's normal. The ticking though is not.
President : SVGTO Tigers
Member
GTO JUDGE is offline   Reply With Quote
Old 08-07-2008, 05:43 PM   #6 (permalink)
2006GTOLS2's Avatar
Many LSx based engines tick. That's just the way it is. Some also have the dreaded "piston slap".
2006 Spice Red M6 - StolenFox Flowmaster Super 44 Axlebacks, StolenFox H-Pipe, U7191 Predator Rev. 9r01 - Custom tuned
2005 Torrid Red M6 - Sold
2001 Chevrolet S10 LS, Pewter Metallic, Ext. Cab, 4.3L, 4L60E, 3.42
2006GTOLS2 is offline   Reply With Quote
Old 08-09-2008, 12:18 PM   #7 (permalink)
LOWET's Avatar
My Photos: (5)
The LS1 and LS2 motors are naturally a little on the noisy side and do have a very mild shake to them when at idle. When was the last time the oil was changed ? Seeing that you bought it used you don't know for sure what type of oil is in it. Change the oil and see if it helps with the noise. As far as the rough idle, again some mild shake is normal but you can check a few items if you think the shake is excessive. Check your wires for a tight connection and make sure none of them are rubbing against your exhaust system. You can also make sure your plugs are snug [ not overly tight ] and maybe pull a few of them to check the electrodes.
JOHN
LOWET is offline   Reply With Quote
Old 08-09-2008, 01:38 PM   #8 (permalink)
I have had the oil changed several times using Mobil 1 synthetic. I was going to swap out the plugs and wires with MSD wires and AC Delco plugs. I also added fuel injector cleaner which has helped with the idle. A coworker of mine who races trans am's said he heard an exhaust leak when I accelerated at a stop sign in the company parking lot right about the place I am hearing the ticking noise. Could this be the noise I hear?
Old 08-09-2008, 02:29 PM   #9 (permalink)
Moderator
My Photos: (16)
Sure, a slight exhaust leak could sound like a ticking.
Restoration pictures password is 'GTO'
Old 08-10-2008, 09:06 AM   #10 (permalink)
LOWET's Avatar
My Photos: (5)
Yes. a exhaust leak sure can make a ticking sound. Bring it back to the shop and get it on a lift to check it out.
Engine code and number Question jay67fast 1964-1974 GTO General Discussion 13 08-03-2007 12:34 PM
cam Q's GTO6 2004-2006 GTO General Discussion 1 10-18-2006 08:34 PM
L76 | GM's Generation IV V8 engine released in Australia 05GTO In the News 4 02-22-2006 11:10 AM
LS-2 Engine Break-In danrieke Engine Discussions 16 12-27-2005 02:43 PM
Worlds Fastest Production Car 05GTO The Lounge 15 11-07-2005 08:45 AM
