Originally Posted by Rukee
So, if a 'tune' is just flashing the ECU to a preprogrammed performance mode, why then do you need another 'tune' for every additional MODs or go-fast items when more are added?? If you flashed it once, why would you need to do it again? How many performance levels are offered in the flash tool? And then, wouldn`t a stock engine benifit from a 'tune' as well?
Every mod you do changes the way in which air is moving in or out of the engine. When you change the way air is moving in or out of the engine the fueling also has to change. That's why you should tune after each set of mods that you do. A stock engine would almost always benefit from a tune as well because usually performance cars come from the factory with a conservative tune.
Hope this helps,
Chris
06 Spice Red M6- Kook's 1 3/4 LT's, Spintech catback, K&N Aircharger, Pedders Street II, SLP predator 455 bobcat tune.
