Old 04-16-2008, 04:09 PM   #1 (permalink)
Torque management system?
So I have been doing allot of reading on the 2006 GTO and I came across the Torque management system? Does anyone have further knowledge into this? What can I do to remove it and if so, what are the pros/cons of doing such a thing?
This is my first GTO so please be nice!
shawnmce is offline   Reply With Quote
Old 04-16-2008, 04:32 PM   #2 (permalink)
fergyflyer's Avatar
There are differing amounts of torque management depending on if you have an A4 or an M6.
Torque management is the computer controlling how much power your car makes at certain times. It does this to protect certain components, like your automatic transmission. The way to remove it is to get a dyno tune, or to get a handheld program like a Diablosport.
The pros are quicker shifts from the automatic and faster throttle response in both cars. The cons are sharper loads on the driveline which can cause U-Joints, transmissions and rear ends to fail.
If you have a warranty, I'd suggest letting the torque management be handled by the computer stock. If you're out of warranty and you want to, you can adjust it, but if something breaks it's on your dime, not GM's.
By removing torque management on an A4 you MIGHT get an extra 2 tenths through the 1/4 mile, in a M6 car it's probably more like a tenth. You'll see more gains from getting a dyno tune and adjusting the Air Fuel mixture and getting the intake air temperature timing curve adjusted than you will from torque management removal.
You will definately notice a difference from a roll in the Auto with much quicker downshifts and less timing being pulled during the shift.
Let me know whatever else you need to know about torque management.
fergyflyer is online now   Reply With Quote
Old 04-16-2008, 11:58 PM   #3 (permalink)
koman's Avatar
Send a message via AIM to koman Send a message via MSN to koman Send a message via Yahoo to koman
from experience torque management being tuned out on a manual car is a waste of time. there's no difference between what i experienced before and afterwards. my throttle response is still sluggish or at least i feel so and other people have said the same of the engine by sound. maybe i had a bad tuner
06 impulse blue/black/ m12 1 of 252
spoilerless with dba 4000 fronts.
78 chevy nova 2dr sbc 400/th350/8.5 (4 jackstand mod)
92 ford rustang lx notchback 5.0/t-5/8.8 LS still stock
FMS shorties, bbk x ,fms catback, air pump overrode.
koman is offline   Reply With Quote
Old 04-17-2008, 07:55 AM   #4 (permalink)
Moderator
My Photos: (16)
Is torque managment the same thing as traction control?
Old 04-17-2008, 09:33 AM   #5 (permalink)
EEZ GOAT's Avatar
My Photos: (28)
Send a message via Yahoo to EEZ GOAT
if an A4 takes off TQ managment, they will loose traction i road in TATS A4 with O% TQ managment and it snapped my neck back so hard i thought we just got rammed by a big rig. he had DR's so it hooked well. with out DR's, the goat will be sideways real fast
EEZ GOAT is offline   Reply With Quote
Old 04-17-2008, 02:21 PM   #6 (permalink)
fergyflyer's Avatar
Torque management and traction control are 2 different but related things. The traction control reduces power when the computer, through the ABS sensors, detects slipage of the drive tires. Traction control can also apply the brakes if the reduction in power doesn't work.
Torque management only comes into play when you have extreme movements of the throttle. It's design is to keep power application smooth to avoid having a shock to the driveline that might damage it. If you are at full throttle and abruptly lift it actually slows the throttle closing by a small amount to reduce the harsh effect on the driveline, so it also works in the opposite direction.
Old 04-30-2008, 08:37 AM   #7 (permalink)
cody6.0's Avatar
My Photos: (1)
Thats one thing that was very annoying about my GTO.
Torque Mangement + Rubber U-Joints = Sloppy
2007 CORVETTE C6 Z51
2007 SILVERADO W/T X-CAB 5.3
2007 SUZUKI GSX-R600
cody6.0 is offline   Reply With Quote
Old 05-06-2008, 05:57 AM   #8 (permalink)
vxssls1's Avatar
Send a message via MSN to vxssls1
just get a tune you will get a few more pony's out of the motor and get the shifts points optimised and firmed up and the tuner will turn off TM
222/224,918,OTR,25% UDP,ported TB,4 into 1's 1 5/8,3"cats,twin 3" X force,ripshift(race)12.7@113,271.5rwkw,364rwhp
vxssls1 is offline   Reply With Quote
Vigilante Torque Converters On Sale For $675.99! tbyrne Supporting Dealers, Tuners and Vendors 3 12-13-2006 04:41 PM
04 torque management socal gto 2004-2006 GTO General Discussion 16 06-05-2006 12:06 PM
Torque Management ??? Toro Toro 2004-2006 GTO General Discussion 16 01-05-2006 08:13 PM
Let's talk torque management kllrvet Service, Maintenance and Technical Discussion 9 10-04-2005 09:34 PM
