Old 11-18-2007, 11:18 PM   #1 (permalink)
Gertythadirtygoat's Avatar
Turbo vs. Supercharger
There seem to be many kits out there for boosting our goats. I need some feedback from people about what they think!
I know the supercharger will help down low and the turbo up high.... but i think i have it down between the Magnacharger supercharger kit and the STS turbo kit. Which one will be the best bang for buck? And im not wanting to go all out, just wanting around 550 whp.
Gertythadirtygoat is offline   Reply With Quote
Old 11-18-2007, 11:54 PM   #2 (permalink)
kgc
S/C or Turbo?
I've had both - turbocharged on my vette and now a Magnacharger on my LS2. Love the low end torque of the SC. Had mine done at LPE and it drives effortless - where you need the power on the street, in the lower rpm areas. Also super easy to tune and plumb.
kgc is offline   Reply With Quote
Old 11-19-2007, 06:06 PM   #3 (permalink)
Which one feels faster to you? i mean even though to vette is a faster car. But how much hp you think the supercharger is putting down?
Old 11-20-2007, 12:38 AM   #4 (permalink)
PDQ GTO's Avatar
My Photos: (10)
kcg, Where do you take the GTO for Mods and tunes here in the Bay?
Thanks,
Rich
PDQ GTO is online now   Reply With Quote
Old 11-20-2007, 08:08 AM   #5 (permalink)
koman's Avatar
Send a message via AIM to koman Send a message via MSN to koman Send a message via Yahoo to koman
from what i have heard the sts turbo kit isn't too great quality wise. so i'd go maggie sc. look into aps or a local shop that will fab you up a turbo kit. turbo you don't have the constant whine as you would with a s/c and you'd probably put down the same amount of power with turbo as you would s/c but with less low end due to the spooling of the turbo. alot of that will depend on turbo size both turbine and housing sizes.
06 impulse blue/black/ m12 1 of 252
spoilerless with dba 4000 fronts. gone
78 chevy nova 2dr sbc 400/th350/8.5 (4 jackstand mod)
92 ford rustang lx notchback 5.0/t-5/8.8 LS still stock
FMS shorties, bbk x ,fms catback, air pump overrode.
koman is offline   Reply With Quote
Old 11-20-2007, 09:30 AM   #6 (permalink)
Chrisco's Avatar
This statement is annoying. Everytime you hear turbo vs supercharger this is what they say. A S/C can get you more high end than a turbo. Centrifugals build boost rapidly the more RPM your motor is spinning. Roots will give you more boost down low. A twin screw would be the best way to go getting mostly mid range. A turbo can get you anything in between. Like koman said, its how you size your turbo. Big turbo means big spool up time means when it finally does spool up in the higher rpm's its crazy. Small turbo means quick spool up in lower rpm's and not as much peak HP. Here's a good writeup on turbos:
http://www.turbobygarrett.com/turbob...o_tech101.html
06 Spice Red M6- Kook's 1 3/4 LT's, Spintech catback, K&N Aircharger, Pedders Street II, SLP predator 455 bobcat tune.
Chrisco is offline   Reply With Quote
Old 11-20-2007, 10:02 AM   #7 (permalink)
hsv
hsv's Avatar
Slp490
Aside from the lower power/torque gain, how would you compare going with something like an SLP490 performance pac over turbo/sc. I'm guessing the hp/torque curve for the SLP490 would not be as flat as turbo/sc but then you are not paying any weight penalty so handling might be a bit better.
Speaking of weight penalty (for handling -- not for acceleration), how does a Maggie SC compare with an APS TT? Seems to me that that the TT with intercooler is going to add a lot of weight to the nose. Does this weight even matter from a handling point of view, or is it negligible?
HSV.
hsv is offline   Reply With Quote
Old 11-20-2007, 02:01 PM   #8 (permalink)
koman's Avatar
HSV.
to keep weight off the nose look at a rear mount turbo. many of the weight issues will depend on your suspension set up. a properly weighted and sprung car will feel far better than a genericly sprung car. if you can get rid of body roll i don't see how the extra weight would hurt the car although i would also suggest looking into lightening when/where you can.
Old 11-20-2007, 02:51 PM   #9 (permalink)
Well if what i said is to annoying for you please dont write anything in my posts anymore. Do us both a favor.
And with what i said the supercharger i was gona go with helps alot more down low and the sts kit doesnt even hit max boost until about 3800 rpms, so therefore that is high end. And those were the two i had picked between.
Thanks everyone else for the input.
Old 11-20-2007, 03:24 PM   #10 (permalink)
hsv
hsv's Avatar
Thanks Koman:
I've seen pictures of the rear-mounted STS turbos, that would be a great way to balance out the weight of the front. Do you know if the rear-mount turbos still need an inter-cooler? I feel like that is going to be the heaviest part of the system.
Ideally, I want to tighten up my suspension with a Pedders Street II/Serious Street kit. My ultimate goal is to have a goat that handles as well as it accelerates
I hear what you are saying about body roll. As I understand it weight towards the front/back of the car is bad as it adds a lot to your "rotational inertia" and makes it harder for the car to rotate quickly about its center of gravity (without using throttle oversteer . The closer the weight is to your car's center of gravity the quicker it will pivot around this point. That's one of the reasons mid-engine cars have such great cornering capability.
Don't get me wrong, I love my Goat and would/will happily drive it stock for a while yet. But there's always the temptation to go that one step better
HSV.
