When I took the stock air box out, I could see the air is being pulled from behind the headlight primarily. Prior to installing my K&N, I added a larger opening to the fender well to draw air in from underneath (behind the fog light). I also sealed the K&N heat shield with some pipe insulation from Home Depot so it effectively made it and airbox in itself. This has completely eliminated the heat soak problem that is so easy to experience in the Texas summers. I can provide some pictures if you like. There are several other small things you can do to improve the GTO's resistance to heat.
05 Brakes w/ C5Pads, K&N CAI, TBCoolantByPass, -CAGS, , +Outlets, DeadPedal, UnSpoiled, GasCapHook, PedalsRightSideUp, HitchToGo,
