I really hope someone can help me out here. Just got the car back from shop. They did transmission oil change, and that's it. Told me shifter assembly is worn, and that's the reason for reverse issue. The whining sound is still just as loud. The technician apparently told service guy it's normal. Most definitely is not. $200 wasted...
Sounds like a R/C car electric motor. It gets louder as RPM's rise, and progressively louder through each higher gear. The sound dissipates after a few seconds of pressing the clutch in, or taking it out of gear into neutral. It winds down, and stops. Another note to make. If I have it out of gear, with clutch pressed all way in, movement into a gear will cause the sound to start. That's before even engaging into the gear slot. You know when it hits that point of resistance?
I really hope someone can help me diagnose this issue as apparently shops are no longer capable of doing their jobs. After they can't fix something just go a head and say the sound is normal when I know it isn't. It started instantly while driving. Not something that developed slowly over time...
Is there any know issues with Monster Stage 1 clutch, or Monster clutches in general creating a whining sound with some type of failure? I really don't think it's the clutch because it only has 5k miles at most on it now. The sound from interior driving seems to be located towards front of vehicle by the engine, and not towards the rear.
This is all the more frustrating because I have the extended warranty, and I really think this is something internal to the transmission that should be covered. Without a diagnostic determining the problem I can't get it fixed, however...
