1970 gto differential cracks - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-19-2017, 02:56 PM Thread Starter
I am restoring a 1970 gto. I pulled the rearend out and replaced the rear control arm bushings and noticed two cracks on each of the ears that the bushings press into on the rearend. Would it be okay just to weld those up or should it be replaced? Thanks
Will post pictures
Bradley Polley is offline
post #2 of 4 (permalink) Old 04-19-2017, 04:57 PM
Quoted: 70 Post(s)
You should be able to have them welded up.
post #3 of 4 (permalink) Old 04-19-2017, 05:23 PM Thread Starter
Here are some pictures on the crack on one of the ears. The other side has a crack as well but it is less visible
ID:	90041   Click image for larger version
post #4 of 4 (permalink) Old 04-19-2017, 05:37 PM
Quoted: 68 Post(s)
Have repaired a cracked upper loop on a '69 Nodular Pontiac 8.2 housing, very valuable rear going back in a RA4 Judge. Cleaned the hsg well, then V'eeed out the crack with small diam die grinder cutoff wheel. We then heated the loop on the hsg with a big propane torch, then carefully welded the prev cracked area with high nickel rod/stick welder. After welding, kept the heat on the welded area with the torch, dinking the surrounding area & the welded area with slag hammer, slowly taking the heat off the effected area.
If the crack is all the way across each loop, & the '70 housing is just a standard gray iron 8.2 housing, I'd weigh the cost of having the R & P setup in another '70-72 Pontiac 8.2 housing. Gray iron center housing Pontiac 8.2's will have an alphanumeric date code in the lower webbing, nodulars only have a 3 digit number which is the Julian date tied to the specific nodular iron Pontiac 8.2 center housing.
Human Verification
Cracks in metal of a-pillar frame/roof...help... oilburner66 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 06-09-2013 10:44 AM
Are these common frame cracks? leeklm 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 12-24-2012 05:55 PM
Factory wheel discoloration and hairline cracks Aspired Wheels and tires 4 04-03-2012 10:40 AM
GTO differential big_mike Service, Maintenance and Technical Discussion 17 12-15-2005 10:16 PM
