B and M shifter leak - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Register Home Forum Active Topics Photo Gallery Insurance Garage Search Today's Posts Mark Forums Read
Old 02-04-2012, 11:13 AM   #1 (permalink)
My Photos: (5)
I bought my car with B/M shifter installed and now it is showing slight leak at top cover plate of trans and shifter base, did B/M have a gasket kit for the shifter base as a fix for this issue? I have a Corba Bobs gasket for the trans cover plate and should seal trans, could I use RTV on shifter base for seal. Has anyone found a fix, I like the shifter and I am using available funds for F/I and motor work. Thanks for the info
SWGOAT is offline   Reply With Quote
Old 02-04-2012, 03:10 PM   #2 (permalink)
87GN06GTO07IRL's Avatar
The gasket or rtv will work. I'd use the gasket since it will not be messy if you need to remove it again.
87GN06GTO07IRL is offline   Reply With Quote
Old 02-05-2012, 10:25 AM   #3 (permalink)
My Photos: (2)
The main issue with the B&M besides it snapping off at an inconvenient time is that it isn't held down at all four corners. Sealing or gasket may help but I've heard of even that not working.
SvedeSpeed OTRCAI|!MAF|HP Tuners|SLP LTs|FTI cam|SLP UD|243 Heads|BBK 80mm|2.5" Exh
Rip Shift|DSS shaft|Diamond Stg3 |Lovells |Koni|Harrop|SuperPro bushes|Pedders|Hotchkis|3.91s
svede1212 is online now   Reply With Quote
Old 02-05-2012, 11:23 PM   #4 (permalink)
646904GTO's Avatar
Not hard to believe either the bolts are stretched or bent or the plate is.
1969 400 T400 auto 2nd owner
1974 350 4 speed 1 of 687
646904GTO is offline   Reply With Quote
Old 02-06-2012, 07:59 AM   #5 (permalink)
BWinc's Avatar
I'd get a Billet, MGW or GMM and ditch the B&M.
Current: MGW-p, H-pipe, SS OTRCAI, Lovell rear springs, Eliminator shocks and Pioneer AVH-P3300BT.... so far. Next: JBA LTs and catless mids Wish list: Intake, modest cam
BWinc is online now   Reply With Quote
A/C leak... Poncho Dan Service, Maintenance and Technical Discussion 2 06-04-2011 03:00 PM
gas leak Topkat 1964-1974 GTO General Discussion 8 05-08-2011 11:37 AM
LS2 Oil Leak pags20 Engine Discussions 11 10-11-2010 02:01 PM
Oil Leak SLVR DOG 2004-2006 GTO General Discussion 1 02-01-2007 11:13 AM
F.S.red stering wheel,shifter and shifter boot 1badgto 2004-2006 GTO Parts for Sale (Price & Pictures Required) 16 11-20-2005 06:21 PM
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
