Pontiac GTO Pontiac GTO Forum
» Sponsors
» Sponsors
Register Home Forum Active Topics Photo Gallery Search Today's Posts Mark Forums Read
GTOforum.com is the premier Pontiac GTO Forum on the internet. Registered Users do not see the above ads.
Old 11-14-2009, 12:07 AM   #1 (permalink)
Broken Axle Shaft.... more pictures
Can someone please explain to me what happened here? I was shifting to 3rd at about 2 grand around 22-25mph.
the car has 98k on it... i bought it sept 08 with 80k.
the bolts are the pieces i found where it broke a block from my house
Broken Axle Shaft-img_10343.jpg  Broken Axle Shaft-img_1045copy.jpg  Broken Axle Shaft-img_1047copy.jpg  Broken Axle Shaft-img_1051copy.jpg
thull97 is offline   Reply With Quote
Old 11-14-2009, 01:47 AM   #2 (permalink)
MJGTOWISH's Avatar
My Photos: (1)
Are you sure?.... If so did you buy it used?
¿ʞuıɥʇ noʎ ʇ,uop 'ǝɹɹɐzıq
helpmerestartmybiz.webs.com
MJGTOWISH is offline   Reply With Quote
Old 11-14-2009, 10:57 AM   #3 (permalink)
Moderator
GM4life's Avatar
My Photos: (15)
Hard to tell, looks like your bolts backed out. They don't look like they broke off.
2004 QS/M12 w/mods
If its not BLOWN it SUCKS!
GM4life is offline   Reply With Quote
Old 11-14-2009, 01:11 PM   #4 (permalink)
Moderator
My Photos: (16)
I would check the other side to be sure they are tight. Replace the bolts and use some blue lock tight.
Restoration pictures password is 'GTO'
Burn-out videos.
Ignition Cylinder Lockup AND Broken! Shorty29 Service, Maintenance and Technical Discussion 2 08-25-2009 04:40 PM
Rear Carrier Axle Stamping Numbers Help!!! Lukeduk1980 1964-1974 GTO General Discussion 1 07-23-2009 10:05 PM
Need help with trans/diff fluid change kegbelly Service, Maintenance and Technical Discussion 29 02-10-2009 01:01 AM
Rearend Marty 2004-2006 GTO General Discussion 107 10-17-2005 10:32 AM
Who is Tremec? jontyrees Service, Maintenance and Technical Discussion 3 04-05-2005 02:27 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
