Old 08-24-2007, 08:54 AM   #1 (permalink)
KinskiGTO's Avatar
Clunking a common problem?
I have never had any odd problems with my GTO since I bought it new, until today. As I backed down my driveway and started to turn the wheel I heard a loud clunk from the right front of the car. I slowed but kept backing out into the street --I heard another 10 or so clunks. After about 30 miles of driving I almost thought the car cured itself, until I parked the car. A guy about 50 feet away asked what was that loud clunk?
Anybody had this problem before? Sounds like its coming from the passenger front, but I can't tell if it's a spring, strut mount, tie-rod, ball joint...
KinskiGTO is offline   Reply With Quote
Old 08-24-2007, 11:20 AM   #2 (permalink)
My Photos: (46)
Without examining it, my bet would be struts. Too many people with various problems with them. The only clunking I had encountered was from the rear diff, not the front end.
President : SVGTO Tigers
Member
Old 08-24-2007, 12:07 PM   #3 (permalink)
KinskiGTO's Avatar
I have it up in the air --rotating the tires-- and I checked everything visually. No strut rub, no play in steering, ball joints and springs seem okay, caliper mounting looks okay, tie-rods seem smooth and not loose. Everything looks okay. Maybe I will check the torque on the upper strut mount?
Noticed a lot more --rack and pinion is leaking, and my compressor has been making the famous knocking noise for some time, now the steering/suspension clunk. Looks like its time for a visit to the dealership but I don't really trust their work and what kind of a mess might I end up with?
I've about decided to trade it in for a G6 and just let the dealership repair it and resell it.
Old 08-24-2007, 12:14 PM   #4 (permalink)
My Photos: (46)
If this is the first problems you have had with it, I wouldn't be too hasty in dumping it yet. Let the warranty cover it and go from there. If you dump it now in haste, you may regret it month or so from now. If this were a problem child I could see being fed up and dumping it.. Let the dealer do their thing and then go from there. IMO.
Member
Old 08-24-2007, 12:28 PM   #5 (permalink)
KinskiGTO's Avatar
That sounds like the thing to do. Maybe I will let them fix the known problems --leaking rack and noisy A/C compressor-- and have them recheck the clunk in the front end. I've just had really bad experiences with dealerships in the past and didn't want to start snowballing the problems due to another bad experience with another dealership.
Old 08-24-2007, 12:49 PM   #6 (permalink)
macgto7004's Avatar
My Photos: (11)
Hey Kinski,
There are a few issues that may contribute to your front end clunking.
There was an issue with the front springs being installed improperly from the factory. There should be a TSB on that. It's a common one.
Another thing to check is the sway bar mounts to see it they may be loose.
Another things, but probably not your issue is with the power steering pump. If I recall, it makes a grinding sound because of a leak or something.
Could also be worn radius rod bushings or strut bushings. All these things the dealer should check.
Like Judge said, don't give up the Goat! You will regret it, besides, from my understanding, G6s have their own steering problems, so much so, that another club member dumped theirs and bought a GP.
Good Luck with it.
Russ
21st Century Muscle, The Soul of a Legend!
70 Palladium Silver HT 400/AT
2004 YJ M6
2008 IOM G8 GT
Secretary, Newsletter Editor, Webmaster, Susquehanna Valley GTO Tigers
http://gtotigers.wordpress.com
macgto7004 is offline   Reply With Quote
Old 08-24-2007, 03:07 PM   #7 (permalink)
KinskiGTO's Avatar
Originally Posted by macgto7004 View Post
Hey Kinski,
Good Luck with it.
Russ
Thanks, and the good news first --I put out one of the fires by myself-- the rack leak was the plug at the bottom of the rack being loose.
I did check a TSB on clunking. The springs look okay and the one TSB I found said to check strut/knuckle bolts and balljoint nut. They were okay. The inner control arm bolt was okay. Sway bar mounts were okay, but the link that connects the SB to the strut was loose. I doubt that was the heavy clunking noise though. The upper strut bolt was tight, and I checked the radius rod bushings for leaks or looseness --looked good. I did see some scratching on my right strut --not the typical tire/strut rubbing-- some light scratches just below that area. I doubt that's the problem either because it just cleaned the dirt off. What I heard should have been taking chunks out of something.
That just leaves the AC problem for the dealer to fix, and solve the clunking problem if I can ever get it to do it again.
I almost checked the Ford site and started to build myself a Mustang --glad I came to my senses in time.
Old 08-24-2007, 03:26 PM   #8 (permalink)
My Photos: (46)
Man you were outta your mind, almost delusional . LOLOL.
We got a good support group here.
Member
Old 08-24-2007, 04:40 PM   #9 (permalink)
KinskiGTO's Avatar
Old 08-27-2007, 01:28 PM   #10 (permalink)
I have just developed the same problem on my '04 at around 40k miles. I'm convinced that it is the upper strut mounts.
motorheadmike is offline   Reply With Quote
