Old 05-09-2008, 01:30 AM   #11 (permalink)
vxssls1's Avatar
Send a message via MSN to vxssls1
Originally Posted by exwrx View Post
Common Myth!!
Perpetuated by cheap, casted rotors. Buy off-brand/questionable rotors, and they will warp, crack etc.... Now, is it possible to warp and crack units that cost almost 10K.... you betcha. BUT, unless your name is on the SCCA, ALMS, or NASA pro-tour drivers list, the only way to warp, crack, or otherwise damage a rotor is almost impossible. The only feasible scenario would be driving through a puddle after a "LLLOOOONNNG" downhill canyon run. The thermal shock "could" warp of even crack your rotor regardless of slots, or X-drills, regardless of cost or quality. If you're warping/cracking your rotors from driving/autocrossing/tracking, buy some better rotors, and/or research the pad/rotor compatibility. A pad that generates and operates in temps of 800-1000 degrees, for obvious reasons can't be matched to a rotor designed to operated in the 500-700 degree temp range.
I have seen it happen to a few rotors and they havent been cheapies ether
yeah if you pay big dollars you wont have a problem but I cant see the merit in it it would have to make them weaker ,I know the V8 supercars over here use slotted rotors
it just my preference but I would never get X drilled rotors
222/224,918,OTR,25% UDP,ported TB,4 into 1's 1 5/8,3"cats,twin 3" X force,ripshift(race)12.7@113,271.5rwkw,364rwhp
vxssls1 is offline   Reply With Quote
Old 05-09-2008, 04:09 AM   #12 (permalink)
Interesting.... I work with a group out here in Cali that hosts track days pretty much every weekend.... and I haven't seen any warped rotors unless someone drove the piss out of them, and then someone being an "Amazing" driver.
Don't know what kind of rotors you're referring to, again, the pad/rotor match-up may be the culprit here (read previous post for a brief on that). Why don't you give DBA a call, since you're an aussie.
In regards to slotting/drilled.... the Drilled weight savings are negligble. The benefit to drilled rotors is the cooling of the rotor itself. Now some say, that due to less mass of the rotor, it will heat up more quickly, negating any benefit from the drilling.
Slots are designed to allow the escape if super-heated gases during extreme braking (the same benefit is claimed by Drilled rotors). The pad will greate a layer of gas, separating it from the rotor, rendering it in-effective. The slotted rotors are designed to not only alleviate the escape of the gases, but also to shave the pad, ensuring a clean (read not glazed) surface.
OEM... well you'll find it all. AMG's have cross drilled. MBZ swears by these, as the drilled work better with cooling. E63, CL63, and any other 63 have massive brake packages.... all drilled. One of my close friends is a tech for MBZ dealership, and in 6 years, has yet to see a cracked rotor.
Again, if you claim to have numerous people telling you that they had warped rotors, before blaming the rotor's drilling/slotting... look at the other factors that would create failures. They are as follows.....
1. Heat: the rotor operated under extreme temps outside it's designed temp range. This could be caused by numerous factors such as incompatible pads, insufficient pad material, keeping the pad pressed against the rotor while extremely hot i.e. stopping the car while rotor and pad are at extreme temps thereby creating hot spots, and uneven heating/cooling areas... or my favorite, driving with the left foot on the brake, while pressing the gas at the same time.
2. Thermal Shock. Extreme temp changes to the rotor. Driving/stopping in a puddle while rotor is extremely hot.
I really can't think of many more reasons for rotors failing. Again, failures are rare, and if they do occur, almost always because of some other factor, not the drill/slotting.
exwrx is online now   Reply With Quote
Old 05-09-2008, 07:11 AM   #13 (permalink)
Moderator
My Photos: (16)
The number 1 reason I see for rotors warping is using an impact wrench to put the wheels on. You should use a torque wrench to ensure all lug nuts are the same tightness. We`re not in the Indy 500!
Old 05-09-2008, 02:41 PM   #14 (permalink)
Though... depending on the wheel, you damage may be more severe to the rim...lol.
Old 05-10-2008, 09:10 PM   #15 (permalink)
2nd that on brake world took me 3 months to get money back. They never answer the phone the person u need is always at lunch. Tell everyone u know dont do business with them HORRIBLE SERVICE.
1gto is offline   Reply With Quote
Old 08-25-2008, 03:10 PM   #16 (permalink)
wutanga13x's Avatar
Send a message via AIM to wutanga13x
full set of dba with hawk pads are like around 600bux
wutanga13x is offline   Reply With Quote
Old 08-25-2008, 09:53 PM   #17 (permalink)
Supporting Vendor
Rob@WretchedMS's Avatar
We now have DBA rotors available, Hawk pads will be available a couple days.
Installations done by Expert Tire of Westfield MA, 322 East Main St, 01085
Cell 860-281-5519 / Shop 413-568-8981 - Expert Tire
MySpace.com/WretchedMS
Rob@WretchedMS is online now   Reply With Quote
Front Brake Enhancements and Upgrades for the GTO (Holden) Xman Drive train, suspension, alignment and brakes. 32 01-15-2008 07:41 PM
Rear Brake Enhancements and Upgrades for the GTO (Holden) Xman Drive train, suspension, alignment and brakes. 11 11-28-2007 10:04 PM
need new rotors, please help! dustyminpin 2004-2006 GTO General Discussion 7 06-11-2007 09:45 PM
1960's GTOs - A must read for collectors! Ultra Slow 1964-1974 GTO General Discussion 4 09-28-2005 12:22 PM
GTO history 05GTO 2004-2006 GTO General Discussion 4 10-10-2004 08:55 PM
