Old 05-08-2007, 07:09 PM   #1 (permalink)
DJ Dannis's Avatar
Send a message via AIM to DJ Dannis Send a message via MSN to DJ Dannis
Fellow owners, Need help with rear diff and dealership
Dear fellow owners who have had their rear diff replaced due to that "howl" at 40-50mph, my dealership is wondering if I can get a copy of the work order and or the VIN number of your vehicle that had the Dana rear end replaced because of this howl. I need to get it done, but despite the TSB, my dealer cannot find anything in stone from GM like part numbers of the new diff, etc. They said it would be best to get the work order from another owner that had this procedure done, or they could take the VIN and lookup what was done. I know we could argue that they should replace it and so on, but they have been good to me so I would just like to play by their game right now to get it done.
I really thank you for your help!
Regards,
Dan
DJ Dannis is offline   Reply With Quote
Old 05-11-2007, 08:29 PM   #2 (permalink)
mtjoy's Avatar
I had mine replaced under warranty they replaced my diff with p/n 92174633, but I believe there's a new p/n 92187413. The work order states "Cause: found worn differential gears causing whining noise. Replaced differential assembly and topped with fluid. F2143 Carrier assembly (complete) rear differential replace 439 WP 2.2. Here's some additional info from ls1gto.com:
http://www.ls2gto.com/forums/showthread.php?t=117377
http://ls1gto.com/forums/showthread....hlight=whining
Also found this TSB on ls1gto.com:
TSB.....#PIP3387D Dana Rear Differential Carrier Parts Availability - keywords broken chatter growl leak noise shudder vibration whine - (Apr 3, 2007)
Document ID# 1951598
2005 Pontiac GTO
Subject: Dana Rear Differential Carrier Parts Availability - keywords broken chatter growl leak noise shudder vibration whine #PIP3387D - (04/03/2007)
Models: 2004-2006 Pontiac GTO
This PI is being superseded to update Condition/Concern and subject line. Please discard PIP3387C.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Any concern with the rear differential carrier in the 2004-2006 Pontiac GTO that would require parts or sealer replacement other than a fluid change, axle seal or pinion seal.
Recommendation/Instructions:
This differential carrier is not serviceable at the dealer. Currently, the assembly will need to be ordered through GMSPO. A SPAC case may be necessary if the assembly is on back order.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
2004 GTO M6
K&N CAI
SLP LM1
Kooks LTs w/ Cats
CCW SP500 18X10, 18X8.5
GMM Ripshift
Powerbond UD Pulley
FTI Rebel TQ Cam
mtjoy is offline   Reply With Quote
