Old 08-26-2007, 07:49 PM   #1 (permalink)
GM weasles out of strut rub problem
Read for yourself. The investigation is closed as of August 8th and I guess GM's lawyers did their jobs well.
NOTE: THE COMPLAINT AND WARRANTY COUNTS GIVEN IN THE FAILURE REPORT SUMMARY OF THIS RESUME INCLUDE ALL RECORDS RELATED TO TIRE WEAR AND WHEEL ALIGNMENT AND ARE NOT LIMITED TO TIRE-STRUT CONTACT. GENERAL MOTORS (GM) IDENTIFIED TWO CONTRIBUTORS TO PREMATURE FRONT TIRE WEAR IN THE SUBJECT VEHICLES. ONE OF THE CONTRIBUTORS CAUSING THE PREMATURE TIRE WEAR WAS OUT OF SPECIFICATION NEGATIVE CAMBER. GM STATED THAT EXCESSIVE NEGATIVE CAMBER COULD BE CAUSED BY IMPROPER CAMBER SETTINGS FROM THE FACTORY OR BENDING OF THE FRONT STRUT ASSEMBLIES DUE TO SHARP ROAD IMPACT (I.E., SEVERE POT HOLES). TO IMPROVE CAMBER SETTINGS FROM THE FACTORY, GM STATED THAT FROM FEBRUARY OF 2005 THROUGH MAY OF 2006 SEVERAL MODIFICATIONS WERE MADE TO THE CAMBER SETTING FIXTURE. GM ALSO NOTED THAT EXCESSIVE NEGATIVE CAMBER COULD RESULT IN FRONT TIRE TO STRUT CONTACT, WHICH COULD ALSO BE CAUSED BY USE OF NON-ORIGINAL EQUIPMENT (OE) TIRES AND/OR WHEELS. GM STATED THAT CONTACT OF THE FRONT TIRE AND FRONT STRUT ASSEMBLY CAN CAUSE A POLISHING ON THE TIRE SIDEWALL AND/OR STRUT ASSEMBLY; HOWEVER, THIS DOES NOT CAUSE A SUDDEN LOSS OF AIR. GENERAL MOTORS PROVIDED ODI WITH THE FINAL FACTORY FRONT CAMBER SETTINGS WHERE AVAILABLE FOR COMPLAINT AND WARRANTY CLAIM VEHICLES. APPROXIMATELY 90 PERCENT OF THESE VEHICLES HAD RIGHT WHEEL CAMBER SETTINGS THAT WERE OUT OF DESIGN SPECIFICATION. FOUR PERCENT OF THE VEHICLES HAD LEFT WHEEL CAMBER SETTINGS THAT WERE OUT OF SPECIFICATION. IN A REVIEW OF CONSUMER COMPLAINTS, MOST NOTED EXCESSIVE TIRE WEAR TO VARYING DEGREES TO BOTH FRONT TIRES. FOR COMPLAINTS INDICATING EXCESSIVE WEAR TO A SINGLE FRONT TIRE, 90 PERCENT INVOLVED THE RIGHT SIDE. ALTHOUGH IN SOME CASES THERE ARE INDICATIONS OF TIRE CONTACT WITH FRONT STRUT ASSEMBLIES IN THE SUBJECT VEHICLES, ANALYSIS OF TIRE WEAR PATTERNS IN PHOTOGRAPHS SHOWS THE GREATEST WEAR OCCURRING ON THE INBOARD TREAD SURFACE FROM ROAD WEAR AND NOT ON THE AREA OF THE TIRE ON THE UPPER SHOULDER THAT CONTACTS THE STRUT. THIS IS CONSISTENT WITH THE KNOWN TIRE WEAR PATTERNS ASSOCIATED WITH EXCESSIVE NEGATIVE CAMBER, WITH OR WITHOUT STRUT CONTACT. THIS IS MOST APPARENT IN SOME PICTURES, WHICH SHOW MINOR TIRE-STRUT CONTACT WHILE EXHIBITING SIGNIFICANT WEAR OF THE INNER TREAD SURFACE OF THE TIRES. BASED ON DATA REVIEWED DURING THE INVESTIGATION, WHILE EXCESSIVE NEGATIVE CAMBER IS AN APPARENT ISSUE, THE PREMATURE TIRE WEAR APPEARS TO BE PRIMARILY CAUSED BY TIRE TO ROAD SURFACE CONTACT AS OPPOSED TO CONTACT OF THE FRONT TIRES TO THE FRONT STRUT ASSEMBLIES. ODI REVIEWED APPROXIMATELY 1,400 TOTAL COMPLAINTS AND WARRANTY CLAIMS POTENTIALLY RELATED TO THE ALLEGED DEFECT. VIRTUALLY ALL OF THE REPORTS RELATE TO UNEVEN/EXCESSIVE TIRE WEAR OR SOME AWARENESS OF THE TIRE-STRUT CONTACT ISSUE. ODI WAS ABLE TO IDENTIFY 9 TIRE AIR LOSS INCIDENTS ALLEGED TO BE CAUSED BY TIRE-STRUT CONTACT, WITH 5 OF THESE DESCRIBING A SLOW AIR LOSS. WHILE THERE WAS EVIDENCE OF TIRE-STRUT CONTACT IN SOME OF THESE VEHICLES, ODI'S ANALYSIS DID NOT FIND THAT THIS CONTACT WAS THE CAUSE OF THE AIR LOSS BUT RATHER A SECONDARY SYMPTOM OF THE EXCESSIVE NEGATIVE CAMBER CONDITION THAT RESULTS IN RAPID ROAD WEAR ON THE INBOARD TREAD SURFACE. ODI IS AWARE OF ONE CRASH ALLEGED TO BE CAUSED BY CONTACT OF THE FRONT STRUT TO FRONT TIRE. HOWEVER, ANALYSIS OF THE INFORMATION PROVIDED BY THE CONSUMER, GM AND A THIRD PARTY INVESTIGATOR DOES NOT INDICATE THAT TIRE-STRUT CONTACT WAS A FACTOR IN THE CRASH. ODI IS UNAWARE OF ANY INJURIES OR FATALITIES ATTRIBUTED TO THE ALLEGED DEFECT. ODI HAS NOT IDENTIFIED A SAFETY RELATED DEFECT TREND IN THE SUBJECT VEHICLES. ACCORDINGLY, THIS INVESTIGATION IS CLOSED. THE CLOSING OF THIS INVESTIGATION DOES NOT CONSTITUTE A FINDING BY NHTSA THAT A SAFETY-RELATED DEFECT DOES NOT EXIST. THE AGENCY WILL CONTINUE TO MONITOR COMPLAINTS AND OTHER INFORMATION RELATING TO THE ALLEGED DEFECT IN THE SUBJECT VEHICLES AND TAKE FURTHER ACTION IN THE FUTURE IF WARRANTED.
DrFix2Fly is offline   Reply With Quote
Old 08-26-2007, 08:12 PM   #2 (permalink)
abright52's Avatar
I don't see any weaseling out of anything in that exerpt.
It states the cause of the strut rub issue.
Read the last two sentances:
2006 Spice Red Metallic
M6 with 17" Wheels
abright52 is offline   Reply With Quote
Old 08-26-2007, 09:43 PM   #3 (permalink)
PEARL JAM's Avatar
My ass. I saw a few of these with tire to strut rub when I worked at Pontiac. If road surface caused inner tire wear, then I guess it was just coincidence that the bottom of the struts had the paint worn off.
2004, .588 lift cam, slp LT's, ported/polished MAF case&throttle body, CAI, Flowmaster Deltas, B&M shortthrow, dragbags, HP Tuners tuned.
PEARL JAM is offline   Reply With Quote
Old 08-27-2007, 07:32 AM   #4 (permalink)
My Photos: (46)
Sounds like a great job of B'sing to me. I guess the roadway is to blame for strut rub deaths. Now I understand.
Vice President : SVGTO Tigers
Member
Old 08-28-2007, 05:29 PM   #5 (permalink)
I'm shocked there's not more outrage over this NHSTA report. All I am sure of is that I am off GM for good and will encourage everyone I know to stop buying GM products. This is the second GM vehicle that left me feeling screwed. Shame on me for giving GM a second chance, but never again. I work too hard for my money and will not waste it with an irresponsible auto maker.
Old 08-28-2007, 05:53 PM   #6 (permalink)
SloTymer's Avatar
What's next, Mustang or Charger? Surely you're not headed to the rice fields are you?
SloTymer is offline   Reply With Quote
Old 08-28-2007, 05:56 PM   #7 (permalink)
My Photos: (46)
The Challenger is looming..... If it checks out....I am fixin on gettin me one.
Member
Old 08-29-2007, 09:12 PM   #8 (permalink)
TORRED1's Avatar
Did have some strut rub upon taking it in for state inspection at the dealer, they found left tierod to be bad and replaced it under warrenty and performed alignment, front right tire was worn as if underinflated but it was not and left was worn on inside, put 4 new general exclaim uhp's on it in a smaller size 235/45ZR17, I understand that is what the original monarro's had on them, so the tierod could have been causing the bad tire wear and strut rub, I will monitor and see how things turn out, but this is not something that can not be resolved, in my case a tierod, but i will not get rid of this car it is to nice and to much fun to drive
TORRED1 is offline   Reply With Quote
Old 09-07-2007, 09:15 AM   #9 (permalink)
Alienhummer's Avatar
My Photos: (2)
Send a message via AIM to Alienhummer Send a message via Yahoo to Alienhummer
19000 miles 2006 model. right front strut shot. Tire down to belts on inside. Alignment was independently tested to be within range. Lef strut is starting to leak. Dealer is replacing them under warranty. Tire pressure was ok and I didn't hit any potholes or anything. GM can kiss my ....... Hummer's Rule the road.
Alienhummer is offline   Reply With Quote
Old 09-07-2007, 06:24 PM   #10 (permalink)
Regarding the last two replies:
Hummers rule the road? Sorry to let you know this, but Hummer is a GM brand. If you have a problem with it, GM will deny the problem is their fault.
Don't buy the tie rod end line. The tie rods effect toe-in, not camber. Camber is the strut rub angle problem. At least your dealer did the right thing and corrected your car with common sense solution like proper tire size.
