I'm ignorant - What will all that nice red stuff do? Will you update us all on how your ride is affected?
Hey malum, Stock Bushings are made of rubber or something like rubber, so stock suspention is "squshy".
This set of bushings is made of Nylon (or something synthetic like Nylon). Material like Nylon doesn't wear out as fast and isn't "squshy". The whole suspension will be tighter/stiffer
That's the best description I can give, If anyone here needs to correct it feel free...
Spice Red 06
11/05 build
VolantCAI
IXiridium Plugs, 10.4 Taylor
GMM
Pedders StreetII+ (1/2" drop)
Hotchkins Swaybars
Full AMSOIL & RP
JBA Shorties/Cats
MagnaFlow w/Xpipe
That's correct. along with "tighter/stiffer " include Rougher. And now that most of the play is out of the suspension system, cars that are pushed hard, break parts. Not trying to sound negative, it's just the trade off when tightening everything up
Ya, stiffer is also a description I should have used.
I guess I should ask: How much stiffer? Anyone installed a Bushing Set?
Spice Red 06
11/05 build
VolantCAI
GMM
Hotchkins Swaybars
Full AMSOIL & RP
JBA Shorties/Cats
MagnaFlow w/Xpipe
After running "Poly Urathane in my '67 Chevelle for 6 months, I took them out and went back to rubber until I discovered Del-A-Lum (Global West). This is on a DD.
