Old 03-28-2008, 01:07 PM   #1 (permalink)
EEZ GOAT's Avatar
My Photos: (28)
Send a message via Yahoo to EEZ GOAT
Need to lift the goat
where can i find springs thats going to raise my goat up about 1 inch? my back tires are scrubbing the inside fender well when i have hit the gas hard, turn corners with a hump, small dips. i looked at web sites but they only talk about lower the car. i guess 1 in should slove my problem and some anti sways inthe back. give me the info. :
EEZ GOAT is offline   Reply With Quote
Old 03-28-2008, 01:38 PM   #2 (permalink)
My Photos: (443)
How about drag bags?
Old 03-28-2008, 01:42 PM   #3 (permalink)
EEZ GOAT's Avatar
My Photos: (28)
my setup is 245/40/18's with a 38mm offset. 18x8.5 wrapped in bf's gforce. i had toyo proxes t1-r same rim same size and did not have any problem cept for a little rub on the fender (rear) lip which has been grind down a lot(may go with 255's or 275's later
Old 03-28-2008, 01:43 PM   #4 (permalink)
EEZ GOAT's Avatar
My Photos: (28)
did not want to make the ride harder. dont that stiffen the springs?
Old 03-28-2008, 02:09 PM   #5 (permalink)
My Photos: (46)
Try Auto anything Air Lift Kits
I seen some on there like the drag bags.
Or you can try this Coil Springs: Car Parts Direct
Vice President : SVGTO Tigers
Member
Old 04-21-2008, 08:52 PM   #6 (permalink)
mtjoy's Avatar
I'm running 18X10 in rims with a 54 mm offset and 275/35 tires and had the same issue as what you're having. With small dips, bumps, etc the tires would rub the inner fender well. I did 2 things fix this:
1) Pulled of the rim to see where the tires where making contact with the inner fender well. I then clearanced these areas, which means I took a hammer and beat the crap out of these areas. After that I sprayed a little undercoating to cover the hammer marks.
2) I replaced the rear springs with stock-height king springs (higher spring rate). Yes the car rode a little rougher, but nothing like after I installed the drag shocks
I hope this helps.
2004 GTO M6
K&N CAI
SLP LM1
Kooks LTs w/ Cats
CCW SP500 18X10, 18X8.5
GMM Ripshift
Powerbond UD Pulley
FTI Rebel TQ Cam
mtjoy is offline   Reply With Quote
Old 05-11-2008, 04:51 PM   #7 (permalink)
Stevo's Avatar
I put the pedders 1 1/2 lift springs on my car. I really like them.
Stevo is offline   Reply With Quote
Old 05-11-2008, 09:26 PM   #8 (permalink)
cncmasterofor's Avatar
From your pictures it looks like your rear springs maybe sagging. You might want to look into Pedders suspension. I know they have a variety of springs.
Also I have the BMR bags. I run 7psi and cant really tell the difference in ride quality.
2006 A4 Brazen Orange GTO
K&N CAI, 18" Chrome Chip Foose Wheels, Tint 20% and 15%, 40 series deltaflow Flowmasters, JBA headers, Blue Tooth, Predator Tune, Catch can, Hotchkis Sway Bars, Pedders springs, Fosgate amps, DLS 8" subs, 6.5" Kenwoods.
cncmasterofor is offline   Reply With Quote
Took the goat out of Barn Today! NJSierra 2004-2006 GTO General Discussion 5 02-03-2008 09:52 AM
Took the goat out of the barn for first time since Mid October!!! NJSierra 2004-2006 GTO General Discussion 4 12-20-2007 10:05 PM
Goat in winter-hopefully no wear and tear?? joeyk97 2004-2006 GTO General Discussion 7 02-18-2007 07:38 PM
cam Q's GTO6 2004-2006 GTO General Discussion 1 10-18-2006 07:34 PM
06 goat vs 72 goat tap goat Racing and kill section 0 07-01-2006 05:48 PM
