Old 03-17-2006, 11:15 PM   #1 (permalink)
HoldenGTO's Avatar
Send a message via Yahoo to HoldenGTO
out of alignment
So, I have been noticing some major wear on the inside of my RF tire and the LF tire, but not as much on the left. Obviously, it has too much toe out. So, I called the dealership to ask if it is covered under warranty and they said only 12k miles or 12 months. I have almost 17K. What kind of crap is that? Why the heck did I even buy the extended warranty if everything is not even covered? This is BS!! Just had to vent.
2004 GTO A4/BLACK/RED
K&N FIILTER - ONLY MOD...SO FAR
"Listen to thine engine and watch thine tach, lest thine whirlybits seek communion with the sun..." - Unknown
HoldenGTO is offline   Reply With Quote
Old 03-17-2006, 11:29 PM   #2 (permalink)
It probably depends on your dealership, but you might try bringing up some of the evidence that this is a common problem on these cars. I've seen where occasionally people have gotten it fixed under warranty (though other people have had no success).
Potentially serious GTO problem - everyone inside!
Clueless is offline   Reply With Quote
Old 03-18-2006, 09:44 AM   #3 (permalink)
Supporting Vendor
Not necessarily. Inside front tire wear is very common on high performance cars such as the GTO and Vette. I see posts like this several times a week on the vette forums.
I don't know the stock GTO alignment specs, but for the Z06, the stock front camber (nominal) is -0.7 and front toe (nominal) is 0.08 degrees (out), though there is a pretty big tolerance on each of these specs. I suspect the GTO is the same. Negative front camber really helps handling. On the track, I am running nearly -3.0 degrees of front camber. Downside to the front negative camber, particularly with toe out (or in), is that it drags the inner edge of the tire along the road when driving straight.
To correct this, I suggest you find the exact GTO alignment specs (maybe someone with a service manual can post them), and get an alignment with front camber within specs but near the low end (less negative) and front toe as near zero as allowed. You will lose a little performance this way, but gain tire wear.
AMSOIL Direct Dealer
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum)
Subdriver is offline   Reply With Quote
