Popping sound 05 M6 - Pontiac GTO Forum
post #1 of 15 (permalink) Old 08-18-2016, 04:29 PM Thread Starter
Quoted: 4 Post(s)
Popping sound 05 M6
Any one ever had a popping sound, come front what seems like the rear diff or driveshaft? It usually happens on about the second drive of the day once everything is warmed up. And it happens when I'm in traffic. It doesn't jolt or anything. When I'm slowly releasing the clutch from first gear it just makes a popcorn kinda sound, almost like the rear diff is stiff and breaks free if you could imagine how that would sound but like i said it doesn't jolt. Or if i get into 5th and keep it at a certian RPM and let off the gas and jump back on it, its not smooth all the time it kidna kinda pops like the drive shaft is loose or something and rocking back and fourth. Anyone know what this could be?
Bryce108 is offline
post #2 of 15 (permalink) Old 08-19-2016, 09:44 AM
GTO44's Avatar
It's the normal slop in the drivetrain. Most everyone with a GTO has experienced this. It's more prominent in the maunal cars. Basically it will pop or clunk when the driveline goes from unloaded to loaded (at a stop and go to take off) or loaded to unloaded (driving and you let off the gas or push the clutch in).
The rear ends on the GTO's were setup with terrible factory specs. Factory backlash is .007" - .012". It should be down around .005. So basically there's a gap between the ring gear and pinion gear. When your moving the gears are meshed and everything is ok. When the driveline is loaded or unloaded the ring gear will clunk against the pinion gear because of that backlash gap.
Here's what I did to get it to go away 90% of the time:
Rear Subframe bushings
Rear Diff insert bushing
Poly motor mounts (Hinson)
Trans Mount with Revshift Bushing Insert
That stuff took a lot of play out of the driveline and quieted down the clunking. It would still happen here and there but not as bad as stock.
Just recently I got a replacement Rearend under extended warranty (ruined my original at the track) and its waaaayyyy clunkier then my original rearend. So depending on how bad your diff is set up, you may get it to go away with the stuff mentioned above, or you may always have it... Unless you have your rearend rebuilt. I'm so tired of the clunking from this replacement rearend, I just bought a Truetrac Diff and am having my original rear rebuilt.
Hope this info helps!
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
post #3 of 15 (permalink) Old 08-19-2016, 08:12 PM Thread Starter
Quoted: 4 Post(s)
Awesome! Thanks for the help! Glad you didn't hit me with some super bad news.... lol Wonder if a new driveshaft and rear diff would make a difference.
Bryce108 is offline
post #4 of 15 (permalink) Old 08-19-2016, 08:38 PM
GTO44's Avatar
No prob! I spent along time chasing that issue lol. Even GM knows about it and didn't warranty it on the factory year cars... said it was normal and not to worry about lol.
And an aftermarket 1 piece ds would probably just accentuate the problem as it's directly connected to the source of the clunk. The factory ds is connected on both ends by rubber and a rubber center carrier bearing.
The only real solution is having the diff rebuilt. That's the stage I'm currently at
I would say your best bet is motor and tranny mounts. I feel like that made the biggest difference in clunk feel. Then you can add the other bushings. Or just do it all at once and get it over with lol. Car feels much better after that stuff.
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is offline
post #5 of 15 (permalink) Old 08-19-2016, 08:44 PM Thread Starter
Quoted: 4 Post(s)
I acutally have new motor mounts sitting right next to me lol and transmisson mount with the blue revshift insert hahahahahah thought that was kinda funny when you mentioned it. And I'm in the process of changing the pinion seal and doing rear diff oil in the next couple weeks
Bryce108 is offline
post #6 of 15 (permalink) Old 08-19-2016, 09:05 PM
GTO44's Avatar
haha nice! Yeah hopefully that stuff helps! I did the diff oil just recently. Pretty easy process but that stuff staaaaaanks lol
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is offline
post #7 of 15 (permalink) Old 08-19-2016, 09:29 PM Thread Starter
Quoted: 4 Post(s)
haHAHAHAHAH o really?
Bryce108 is offline
post #8 of 15 (permalink) Old 08-21-2016, 10:42 AM
Quoted: 24 Post(s)
Does it matter it you are turning or going straight when it makes that sound or is one worse than the other?
post #9 of 15 (permalink) Old 08-23-2016, 04:19 PM Thread Starter
Quoted: 4 Post(s)
Sometimes in reverse it REALLY makes a popping sound. and I do hear a pop I want to say at like a perfect cruise in 3rd at like 25mph when i hit bumps and turn. I notice it then, in reverse sometimes, and mostly on the second drive of the day out of first in traffic, or if i play with the gas pedal in like 5th and make sudden gas changes like take my foot off completely in 5th and then just back on it to maintain speed
Bryce108 is offline
post #10 of 15 (permalink) Old 08-24-2016, 12:36 AM
GTO44's Avatar
If this helps...
I found that after a while of owning the car I actually changed my driving style to deal with that clunking. I hate annoying sounds and It was a while before I was able to replace all the bushings. So I used these techniques to help deal with it on the daily.
-I slip the clutch a little more on take off, easing into the rolling motion. This smoothly engages everything and it should be more quiet.
-Rev matching... I always blip the the throttle before releasing the clutch when moving. Especially when downshifting. The closer the engine speed is to drliveline speed during engagment, the less clunk there is... or you can avoid it all together. I made this a huge habit. Will also reduce wear and tear on your clutch.
-If driving at speed and let off, ease back onto the gas gently, then mash it or maintain speed. That will usually avoid the clunk too.
Of course that's not accounting for "spirited driving" or "hot rodding"
It's no "solution" but has kept me from pulling my hair out when im in traffic lol After almost 5 years of owning the car I'm finally going to get the diff rebuilt and hopefully never hear a clunk again.
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is offline
Human Verification
Popping Sound during acceleration vera_jr 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 26 04-26-2014 01:02 AM
'04 Trunk not popping?? purplelover Service, Maintenance and Technical Discussion 12 07-08-2010 08:39 AM
Drivers Door makes a popping sound when closing 06cyclonegto Interior Discussions 3 07-07-2010 03:47 PM
Popping noise? Wade M 2004-2006 GTO General Discussion 6 11-23-2006 08:25 AM
loud popping!! wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 4 01-29-2006 01:48 PM
