is it normal? on a turn when i go into throtle only one of the wheels spin (im getting the old fashion one wheel fire intstead of going sideways.)it seems ok when i punch it from the dead stop going in a straight line, did that ever happend to anyone.
also have another? i looked online and i cant find anything about the posi upgrade, or gears, where can i find a gear upgrade for my goat.
I noticed the same thing when traction control is on. It kinda like a handicap were it helps you go the direction you want with out you looking at your tail lights. You will have to turn off traction control each time you turn on your car to get all ass sideways.
did that and same thing one wheel fire with trac off.
If it was a Torsen or a weak sprung clutch pac differential I would say it was normal at times. But the GTO uses a cone type diff and it should be set up tight and be able to eventually lock both wheels in a corner.
If it only lets one tire spin especiallt the right side during really tight right turns it's kinda normal. If it lets the inside tire only spin in all turns tight and long you have a problem.
While cruising down the road at 35-40mph I have kicked the goat hard and twice the rear wanted to come around!!! Traction controll was on!!! It is a beautiful thing!!!
