Old 07-05-2008, 02:37 AM   #11 (permalink)
cncmasterofor's Avatar
IMO Hotchkis sways are a great starting point. The best bang for the buck. My settings are on the slightly stiffer side. But that where my car likes it.
As for the rest. I mixed and matched them. Pedders springs, strut/mounts with and bearings. And Noltec bushings all around. It's all about who ever has the best deal at the time. Now there are a few others out their like Koller and Lovells. Which I believe are the same as Noltec.
2006 A4 Brazen Orange GTO
K&N CAI, 18" Chrome Chip Foose Wheels, Tint 20% and 15%, 40 series deltaflow Flowmasters, JBA headers, Blue Tooth, Predator Tune, Catch can, Hotchkis Sway Bars, Pedders springs, Fosgate amps, DLS 8" subs, 6.5" Kenwoods.
cncmasterofor is offline   Reply With Quote
Old 07-06-2008, 03:29 PM   #12 (permalink)
1/4 mile = 12.505 @ 112.07
My Photos: (2)
Koller Racing is the Lovells distributor. you can save on any part that Lovells makes over Pedders plus some parts like their strut mounts are superior being poly instead of rubber without any difference in NVH. Lovells bushes are the same as Noltec but their springs are their own. the Lovells bush from Koller Racing is usually cheaper than Noltec tho.
12.34 ET, 113.55 MPH
1.82 60ft
DIY OTRCAI|!MAF|HP Tuners|SLP LTs|FTI cam|SLP UD|BBK 80mm TB|2.5" Exh
Rip Shift|DiffTechshaft|Diamond Stg3 clutch|BFG DRs|Lovells springs|Koni|Harrop cover|SuperPro bushes|Hotchkis sways|3.91s
svede1212 is offline   Reply With Quote
Old 09-28-2008, 03:16 PM   #13 (permalink)
The intimidator's Avatar
Originally Posted by 400goatpower View Post
Hey guys, I don't have a lot of money to put towards the goat but it desperately needs suspension modding for my taste. I don't want to spend over 1500-2000$ for a setup like pedders, even though I hear it's the best. Is there a cheaper alternative? I come from an RX-8 and the handling was unreal and I want to make the goat handle and brake a little bit better. I was thinking a set of hotchkis sway bars, slotted rotors, and stainless steal break lines. This was the typical setup on the RX-8 that people did for suspension. Maybe someone could just point me in the right direction?
Put an H&R springs kit on your car I have one it rocks!! Got mine from tirerack.com $265 to my door and I live in Hawaii!
The intimidator is offline   Reply With Quote
Old 10-01-2008, 12:34 AM   #14 (permalink)
Rob@WretchedMS's Avatar
The GTO comes with a number of weak areas and no matter what you do to it, it will not handle like an RX8. Though there are areas that you can make a good amount of improvement.
The Wretched Repair kit contains 7 of the most replaced parts on it, and will transform your GTO in to the car that it should have been from the factory.
Read More Here
I have a complete Track 2 suspension (and then some) on my car, which is every bushing, spring, damper, sway bar, links, and strut tower bar. It contains everything that you will need to make your car handle at it's highest level.
Our parts also come with the best warranty in the business, with no exclusions for other mods, or racing.
Replacing the sway bars first is not what i'd do for a first step, as there are other more important areas that you can get more improvement from.
Installations done by Expert Tire of Westfield MA, 322 East Main St, 01085
Cell 860-281-5519 / Shop 413-568-8981 - Expert Tire
MySpace.com/WretchedMS
Rob@WretchedMS is offline   Reply With Quote
Old 10-01-2008, 03:24 PM   #15 (permalink)
Read More Here
with the sway bar comment. Adding sway bars puts tremendous strain on other areas of your suspension, and could easily cause premature failure on any number of other parts.
In regards to the hate on pedders kits..... welll they've taken the guess work out of the equation. You can't just buy any bushing kit, shocks, springs, etc... and expect it to handle well. Seat of the pants is never a good way to determine your cars handling ability. Pedders ensures that their kits seamlessly work togther to get results.
I'm not a huge fan of pedders, and am always looking for other options, but the fact that you're guaranteed improved performance... should mean something.
It's so obvious if you think about it. You can't just go out, buy any header, intake, cam, and tune and expect to get good results. A poorly picked/misapplied cam, header or intake might even net you less area under curve than you have now.
Let's face it! Who can honestly say that their package outperforms the pedders kit on instrumented tests? I'm not saying it's impossible, but I'd love to hear the alternatives.
exwrx is offline   Reply With Quote
Old 10-01-2008, 03:32 PM   #16 (permalink)
On this note... the track II package you list, contains a new strut bar. Any particular benefit that was measureable? Was it needed? Is it possible to order/install the Track II without the new strut bar? Any price difference?
Just a curiousity, as there are a number of such bars on the market, and I've rarely seen improvements over the OEM one that were measureable. Other than "bling" or weight savings.... what benefit would YOU say there is in replacing it?
Old 10-01-2008, 08:20 PM   #17 (permalink)
The Track 2 kit that i have listed is priced with out the strut tower bar, if you want to add that you can on the order page.
The GTO Strut tower bar is an improvement over the stock unit, and it also adds adjustability because you can set it to have a bit of positive or negative tension.
The Sway bars make a big difference, there are a few brands out that do now make a big difference, but ours most definitely do.You gain adjustability of both the front and the rear bar, which is important to setting up the car. I had the Track 2 on my GTO with out the bars, and was very happy with the car, i then added the bars to the mix and it gave it the extra stiffness i was looking for.
Old 10-16-2008, 05:18 PM   #18 (permalink)
I find it interesting that though options have been presented, no tests/timeslips have made it onto the page showing/proving a better setup than pedders.
I challenge all of you to prove me wrong, as I hope you will, since I, like everyone else, don't enjoy spending $2K on a suspension setup. Especially one that isn't adjustable. I have ridden/driven the Track II and Street II and was very impressed by both. I couldn't tell much of a difference between them as I wasn't able to really push, or wring out either vehicle.
It hurts me every time I look at parts for this car. I came from the import world, where basic coilover systems from TEIN are $800. New pads and rotors being less than $350 all around. It sucks that parts are so damn expensive for this car. Even performance pieces are much more expensive than they were for imports.... or at least Japanese Imports.
Now... the fact that i can get OEM replacement parts such as oil filters, etc... at Autozone is just priceless. lol.
Back to the topic at hand though, the Lovells shocks that were mentioned previously.... how much are we talking for a comparable setup? Let's say I get the Lovells shocks, Noltec bushings, etc... what results are expected?
Old 11-05-2008, 08:09 PM   #19 (permalink)
My Photos: (2)
are you looking to wring every 1/100th sec track time out of it? any concern about street manners? Kings make some great springs for the track that aren't that fun to drive on the street. i would argue that mixing a control arm bushing of one brand with a subframe bushing of another with a strut mount of a third isn't going to be a problem. my Lovells springs with Koni adjustable struts and shocks work very well in a variety of conditions. i have Hotchkis, Koni, Lovells, Pedders, Energy Suspension and Super Pro parts. anybody that drove it i believe would be impressed with it's handling. another thing to consider is you can have the best of the best of all that stuff and without the very, very best tires you are leaving a lot on the table. you have to find the balance of price, performance and driving needs that fit you.
1.82 60ft
Old 11-06-2008, 02:44 PM   #20 (permalink)
Svede... I agree completely.
The 3 most important peformance upgrades to any track car, and secrets to shaving times are....
1. Driver
2. Tires
3. Brakes
the rest is ambiguous and debateable ad infinitum. I'm glad you have a setup that works, what I was pointing out was that Pedders had simply taken all the research out of it. The Track II Rides great on streets, as does the street II, and still significantly improve the ability of this car to perform on the track.
There are a slew of other parts out there, sooo, I don't doubt some combo netting a slight edge in price and performance. But what are they? Because unless you do some pre-post testing, how do we know that a stiffer ride, means a better handling one? lol.
suspension setup? wutanga13x Drive train, suspension, alignment and brakes. 2 02-01-2008 02:24 AM
72 suspension questions ksucatz 1964-1974 GTO Restoration and Technical Discussions 8 11-25-2007 10:33 AM
68 power window setup for sale+++ musclecar-mania 1964-1974 GTO parts needed or for sale 0 09-26-2007 06:31 PM
Suspension Airbag Setup Vs. Regular Suspension Setup MJGTOWISH 2004-2006 GTO General Discussion 8 06-20-2006 10:23 AM
Suspension I Stall Automatics Drive train, suspension, alignment and brakes. 17 03-16-2006 01:50 PM
