Steel vs Aluminum Flywheel - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-13-2011, 01:29 PM Thread Starter
JimmyFox's Avatar
Send a message via Skype™ to JimmyFox
Aluminum flywheels are lighter which I would assume is better for performance.
I've also heard that if you have a heavy car (GTO) that you want a steel flywheel. Could someone clear this up please?
JimmyFox is offline
post #2 of 4 (permalink) Old 01-13-2011, 02:01 PM
flywheel
I have a 455 550 hp. I talked to Mr. Pontiac Jim Butler. He said with that much hp run a steel flywheel. He said a stock alum flywheel would scatter the first time you hammered it. I'm sure there are aftermarket alum or alum alloy heat treated to a T8 that would work but it has to be solid. No lightening holes.
They have a 64 tempest that ran 228 mph in a 1/4.
bullet20cc is offline
post #3 of 4 (permalink) Old 01-13-2011, 06:20 PM
dstryr's Avatar
I have the understanding that if your engine can recover quickly from the RPM drop at the hit and gear changes then the aluminum will be quicker. But if your specific combination needs the inertia of a heavy wheel then it will run more consistent and not bog on a launch unless your RPMs are way up there. Lighter car and taller gear => alum/lighter, heavy car and lower gear => steel/heavier.
Here's a good article, flywheel discussion is a ways down.
http://www.popularhotrodding.com/fea...ase/index.html
dstryr, since 1986.
dstryr is offline
post #4 of 4 (permalink) Old 01-19-2011, 02:11 PM
KyleGT05usmc's Avatar
Maybe if you're running Nurburgring everyday you could benefit from the lightweight flywheel.
until then stick with the heavier. the lightwgt is too light and has tons of clutch shutter in daily driving. and no real benefits of holding rpms between shifts that i noticed.
also you have to think about how heavy the car is, by reducing the rotating mass(by going LW flywheel) you're going to hinder yourself in low end torque. thus more rpms will be required to move the car from the start. i had to start at about 2k RPM from a stop just to avoid clutch shutter. i went back to steel and ill never go lightweight again.
K&N CAI, lightly ported stock TB/INT, JBA Hpipe, Spintech Side Exh. (13.1@106 r/t .8800 60' 2.06)
1/13/10- Kooks 1 3/4, LS7 Clutch, B&M shifter
1/21/11 - Eibach Springs, Monroe Shocks, EBC Brakes
Soon - "Sungold" PowderCoated 17"s
KyleGT05usmc is offline
Human Verification
Tell Me About Steel! WideTrack 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 17 01-17-2010 12:15 PM
Fidanza Aluminum LS7 flywheel. $200 LYNMUP 2004-2006 GTO Parts for Sale (Price & Pictures Required) 6 07-13-2009 03:54 PM
NEW Spec Steel Flywheel for sale SANDU002 2004-2006 GTO Parts for Sale (Price & Pictures Required) 1 03-20-2007 07:44 PM
FS: Spec Aluminum Flywheel LS2Bluegoat 2004-2006 GTO Parts for Sale (Price & Pictures Required) 0 08-25-2006 11:05 PM
